R45 - 433MHZ Send Doesn't Work Anymore
killerfreek
#1 Post by killerfreek » 26 Feb 2017, 14:24
I have been trying in vein to get R45 installed and working on my gateway without luck. It flashes fine and appears to work fine, with Domoticz receiving both 2.4 and 433Mhz signals. However, when sending a 433MHZ signal, it shows as sucsessful but sends nothing.
I have tried using the RFLink Loader to send the commands directly from that and it shows an OK with a binary response but again, it doesn't actually send anything (Well, my devices do not respond, I could do with another RFLink to monitor what is actually being sent I guess).
If I revert back to R44, everything works just fine again. I read that shorting 12 and 13 to clear eeprom might work, that didn't for me anyway. I have tried multiple downloads in case of corrupt files etc. Same results every time.
Any Ideas on why or what to try next?
Stuntteam
Site Beheer
Re: R45 - 433MHZ Send Doesn't Work Anymore
#2 Post by Stuntteam » 26 Feb 2017, 15:11
check your email..
killerfreek
#3 Post by killerfreek » 26 Feb 2017, 16:48
Many thanks, was not expecting a response so quick and I can confirm it works a charm! Problems all gone and 433 is sending perfectly!
Many thanks, really appreciate it! :-)
Kris
salomon
#4 Post by salomon » 01 Jun 2019, 11:25
Would you mind sharing the solution?
bojan
#5 Post by bojan » 03 Jun 2019, 13:56
Stuntteam wrote: 26 Feb 2017, 15:11 check your email..
This is not how the public forum should work. Please share.
Stuntteam
Site Beheer
#6 Post by Stuntteam » 03 Jun 2019, 17:36
It was a specific issue back in 2017 with a very old release.
This is no longer relevant for the current release version.
