Issue with multiple BrelMotors
rs27776
#1 Post by rs27776 » 22 Dec 2019, 01:07
Hi All - I'm having a strange issue with RFLink and two identical roller blinds.
RFLink identifies both BrelMotors with an ID of 494395 and a switch of 31 and 32.
The issue I have is I can send a command to 31 and it works but when I send it to 32 that roller blind does not work.
Has anyone had this issue and solved it? The output from RFLink loader is below.
Thanks in advance for any help.
Rick
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
10;version;
20;01;VER=1.1;REV=48;BUILD=04;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
20;03;BrelMotor;ID=494395;SWITCH=31;CMD=DOWN;
20;04;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
20;05;BrelMotor;ID=494395;SWITCH=32;CMD=DOWN;
20;06;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
10;BrelMotor;494395;31;DOWN;
20;07;OK;
20;08;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
10;BrelMotor;494395;32;DOWN;
20;09;OK;
Stuntteam
Site Beheer
Re: Issue with multiple BrelMotors
#2 Post by Stuntteam » 22 Dec 2019, 23:47
Make a debug log as described on the rflink homepage to get this sorted out.
rs27776
#3 Post by rs27776 » 23 Dec 2019, 00:41
Thanks for the reply Stuntteam.
Below is the output of the same commands with debug on:
Please let me know if I can provide anything else.
Kind regards
Rick
10;version;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,300,600,300,240,630,240,630,600,270,240,630,600,270,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,240,660,600,330,240,630,240,630,600,270,600,270,240,630,240,630,600,300,600,330,4710,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,330,240,660,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,600,330,4680,1440,240,660,600,300,240,660,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,300,240,630,240,660,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,330,240,630,240,630,600,300,600,300,240,660,240,660,600,300,600,6990;
20;05;BrelMotor;ID=494395;SWITCH=31;CMD=DOWN;
20;06;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,300,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,270,240,630,600,330,4710,1440,240,630,600,300,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,300,240,630,600,6990;
20;07;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
20;08;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,300,240,630,240,630,600,300,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,240,660,240,630,240,630,600,300,600,300,240,630,240,630,600,300,600,330,4710,1440,240,630,600,270,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,660,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,300,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,600,300,240,660,240,660,240,630,600,270,600,270,240,630,240,630,600,270,600,330,4680,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,660,600,330,240,630,240,630,600,300,600,270,240,630,240,630,600,270,240,660,240,630,240,630,600,300,600,270,240,630,240,630,600,300,600,6990;
20;09;BrelMotor;ID=494395;SWITCH=32;CMD=DOWN;
20;0A;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,300,240,660,240,630,600,300,240,630,600,300,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,330,600,300,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,240,660,240,630,600,270,240,630,600,300,240,630,600,270,240,630,600,300,4710,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,300,240,630,600,270,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,300,240,630,600,6990;
20;0B;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
10;BrelMotor;494395;31;DOWN; (This Works)
20;0C;OK;
20;0D;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,270,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,270,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,300,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,270,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,6990;
20;0E;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
10;BrelMotor;494395;32;DOWN; (This dosn't work)
20;0F;OK;
20;10;DEBUG;Pulses=246;Pulses(uSec)=4770,1410,240,630,600,270,240,630,270,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,300,4710,1410,240,630,600,270,270,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,6990;
20;11;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
