Rules, cannot get Publish (to mqtt) working
JR01
#1 Post by JR01 » 25 Oct 2020, 19:45
Hi, I have an ESP on a gate, I want it to publish directly to my Homebridge server on topic homebridge/to/set to update the status of the garage door as the switches monitoring the door state is switched on / off. The Rules below does not send the MQTT code. I do receive normal mqtt updates from the device on its set Controller topic - thus mqtt is functioning. (homie/%sysname%/%tskname%/%valname%). the registered devices are hooked up to open / close reeds which reads if the door is opened, or closed:
1) Device: GateClosed, Value: Status
2) Device: GateOpened, Value: Status
// ---- Send status when open or closed ----------
on GateClosed#Status=1.00 do    // door closed
  event,publishHK='CurrentDoorState',1
  event,publishHK='TargetDoorState',1
on GateClosed#Status=0.00 do    // door just opening from closed
  event,publishHK='CurrentDoorState',2
  event,publishHK='TargetDoorState',0
On publishHK Do
  Publish homebridge/to/set,'{"name":"ESP66.Gate1.relay","service_name":"Garage Door","characteristic":"%eventvalue1%","value":%eventvalue2%}'
EndOn
Can anybody spot issues with above rule?
Re: Rules, cannot get Publish (to mqtt) working
#2 Post by Ath » 25 Oct 2020, 20:21
You can't pass strings to an event in this way. Strings are not a 'first class citizen' yet, in ESPEasy, you can only pass numeric values to an event.
Within the event you can select the desired subject using the if statement:
on GateClosed#Status=1 do    // door closed
  event,publishHK=1,1  // CurrentDoorState 1
  event,publishHK=2,1  // TargetDoorState 1
on GateClosed#Status=0 do    // door just opening from closed
  event,publishHK=1,2  // CurrentDoorState 2
  event,publishHK=2,0  // TargetDoorState 0
On publishHK Do
  if %eventvalue1%=1
    Publish homebridge/to/set,'{"name":"ESP66.Gate1.relay","service_name":"Garage Door","characteristic":"CurrentDoorState","value":%eventvalue2%}'
  if %eventvalue1%=2
    Publish homebridge/to/set,'{"name":"ESP66.Gate1.relay","service_name":"Garage Door","characteristic":"TargetDoorState","value":%eventvalue2%}'
  // add more if needed
EndOn
Assuming the ESP's name is ESP66, you can replace that with %sysname%, to make your script a bit more portable, if desired.
JR01
Solved: Rules, cannot get Publish (to mqtt) working
#3 Post by JR01 » 25 Oct 2020, 20:44
Just tried it - it works, thank you !
JR01
#4 Post by JR01 » 25 Oct 2020, 21:53
The above help should be in the Rules documentation, seriously.....
https://espeasy.readthedocs.io/en/lates ... Rules.html
Users browsing this forum: No registered users and 44 guests
