remko2000
#1
Post
by remko2000 » 22 Nov 2020, 14:23
I've an espeasy CO2 sensor and with this I want to send a window open. A can control my axa remote (= window opener) with this call from domoticz:
So I thought I make a rule which send this command when my CO2 sensor reach a value of 2500 ppm. This is my rule:
On CO2#PPM do
if [CO2#PPM]>2500
SendToHTTP http://10.0.1.102/open
Problem is that this doesn't work. I read the wiki with tutorial rules but I don't find a proper example so this isn't help me. Someone any suggestions?
#2
Post
by Ath » 22 Nov 2020, 14:54
You have the syntax for SendToHTTP wrong,
it should be something like this:
On CO2#PPM do
if [CO2#PPM]>2500
SendToHTTP,10.0.1.102,80,/open
- No protocol prefix (ESPEasy only supports http, and that is implied by the command)
- Separate arguments for ip/hostname, port and file/location
The command syntax can be found here:
https://espeasy.readthedocs.io/en/lates ... mmand.html
remko2000
#3
Post
by remko2000 » 23 Nov 2020, 16:50
Indeed:
On CO2#PPM do
if [CO2#PPM]>900
SendToHTTP,10.0.1.125,80,/open
SendToHTTP,10.0.1.125,80,/close
does the job.
The thing I don't like is the fact that my esp with CO2sensor constantly send 10.0.1.120,80,/open of 10.0.1.120,80,/close (dependig of the tresshold). It would be better when this wemos only send one command when it reaches the thresshold and one when it falls below the thresshold. Is this possible?
Post
by TD-er » 23 Nov 2020, 16:56
You can have a look at the "level" plugin to implement some kind of hysteresis like behavior.
remko2000
#5
Post
by remko2000 » 25 Nov 2020, 17:34
I read the wiki of this levelplugin but I see it's combined a setpoint with an action on a GPIO (high of low). I don't want to have an action on a GPIO, I want to have a httprequest when the setpoint is reached. I don't read there is a possibility to do something like this?
#6
Post
by Ath » 25 Nov 2020, 19:43
remko2000 wrote: ↑25 Nov 2020, 17:34
You can add an event in the rules to achieve what you want, leave the gpio set to none
on level#output do
If %eventvalue%=1
Sendtohttp,.... // 'on' command
Sendtohttp,.... // 'off' command
