Rules: can <if statement> work before Clock#Time ?
JR01
#1 Post by JR01 » 29 Nov 2020, 21:28
Hi, will below work? i.e. will the clock#time do the evaluation embedded in a if statement? Or should it be the other way ariund, 1st the clock#time statement to trigger @ the correct time- and then the if statement? (Below does not seam to work - but I want to confirm).
if Vars2#Auto=1 and Vars2#AutoGardener=0
  On Clock#Time=All,10:00 do
    event,L1
  On Clock#Time=All,11:00 do
    event,L2
  On Clock#Time=All,12:00 do
    event,L3
  On Clock#Time=All,13:00 do
    event,L4
Re: Rules: can <if statement> work before Clock#Time ?
#2 Post by TD-er » 29 Nov 2020, 22:19
The wrapping if statement will not work.
When processing the rules, the parser tries to find an "on ... do" sentence and tries to match the event with the text on the 3 dots in my example sentence.
There is no condition check outside the on ... do ... endon scope.
JR01
#3 Post by JR01 » 30 Nov 2020, 16:01
Thank you. Thought so.
