I am currently trying to build a CO2 display with a neopixel ring. However, the display does not work so far because I can only find insufficient information about the NeoPixelLine command:
viewtopic.php?t=7991&p=47186
NeoPixelLine 1,4,0,255,0
the first 4 pixels should light up green, but only the first Pixel light up
(ESP_Easy_mega_20201130_normal_ESP8266_4M1M)
CO2-measurement with MH-Z19b / Neopixel / 7 segment display
Re: NeoPixelLine ??
Do you use a level shifter for Neopixel?
Re: NeoPixelLine ??
FWIW, the command usage is shown in the P038_NeoPixel Plugin's source. See snippet excerpt below.... so far because I can only find insufficient information about the NeoPixelLine command
// List of commands:
// (1) NeoPixel,<led nr>,<red 0-255>,<green 0-255>,<blue 0-255>
// (2) NeoPixelAll,<red 0-255>,<green 0-255>,<blue 0-255>
// (3) NeoPixelLine,<start led nr>,<stop led nr>,<red 0-255>,<green 0-255>,<blue 0-255>
// Usage:
// (1): Set RGB Color to specified LED number (eg. NeoPixel,5,255,255,255)
// (2): Set all LED to specified color (eg. NeoPixelAll,255,255,255)
// If you use 'NeoPixelAll' this will off all LED (like NeoPixelAll,0,0,0)
// (3): Set color LED between <start led nr> and <stop led nr> to specified color (eg. NeoPixelLine,1,6,255,255,255)
//RGBW note:
// for RGBW strips append the additional <brightness> to the commands
// eg: NeoPixel,<led nr>,<red 0-255>,<green 0-255>,<blue 0-255>,<brightness 0-255>
// The NeoPixelLine command does not work for RGBW, cause espeasy currently only allows max. 5 parameters
//Added HSV compatibility for Homie convention and others
// Hue, Satuation and Value (Intensity/Brightness) is a more human readable and easier to adjust color space with only 3 values
// can therfor be used for RGBW LEDs too without limitations mentioned above.
// expects Hue from 0-360° and satuation and value form 0-100% so can be used with integers too.
// Used functions HUE2RGB & HUE2RGBW can handle float and are precice but not optimized for speed!
Re: NeoPixelLine ??
Thank you for your many hints. It was actually my own fault. LED count was at 1
A level converter was not necessary as long as I didn't put a resistor in the signal line to the Neopixel ring. Now everything works and all only needs a home.
If someone is also interested in CO2 measurement, here are my photos and informations:
on CO2MHZ#PPM do
SendToHTTP 192.168.178.19,8080,/json.htm?param=udevice&type=command&idx=1392&nvalue=[CO2MHZ#PPM]
7dn,[CO2MHZ#PPM]
TaskValueSet 3,1,(([CO2MHZ#PPM]/100)-3)
TaskValueSet 3,2,([Speicher#Num]-2)
NeopixelLine,[Speicher#Num1],24,0,0,0
if [CO2MHZ#PPM]>1501
NeoPixelLine,1,[Speicher#Num],3,0,1 // LEDs pink
Elseif [CO2MHZ#PPM]>1201
NeoPixelLine,1,[Speicher#Num],3,0,0 // LEDs red
Elseif [CO2MHZ#PPM]>901
NeoPixelLine,1,[Speicher#Num],4,1,0 // LEDs orange
Elseif [CO2MHZ#PPM]>701
NeoPixelLine,1,[Speicher#Num],3,2,0 // LEDs yellow
Else
NeoPixelLine,1,[Speicher#Num],0,3,0 // LEDs green
Endif
Re: CO2-measurement with MH-Z19b / Neopixel / 7 segment display
