ESP-01 no Accesspoint after Flashing
flashed an ESP-01 and another ESP-13 with the newest R78-Firmware (512k). Flashing with Esp-Flasher was ok, but after a reboot there are no accesspoints to log in.
Other ESP-Moduls like NodeMCU are ok.
Thank you for your great work.
Robin
Robin
Re: ESP-01 no Accesspoint after Flashing
two days ago something similar was discussed here:
http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1056
Thank you for your quick help.
I installed the easyESP system on my PC (i usually work with mac). I installed a esp8266 2.1rc from the library and i got something strange.
The esp8266-01 got flashed but i see only a few seconds the AP, then the blue led lights off. then on for a time and so on. i thought off the current. so i tried a different power supply and the same problem. its look that the esp makes a reboot. i tried with two different 01.
What is the output/ messages from the serial Monitor?
Very very strange,
if i am starting this with arduino Serial monitor it works! I have an accesspoint ESP_0
if i am starting this with an powersupply i haven't a AP.
Here my log
Here my log
=>l7d848
3fff64a0: 3825526d 5685a93d 9ac999f6 045255f8
3fff64b0: 4410b3c1 315eb334 5340d3d8 35ba1968
3fff64c0: 3e081416 869ed054 9fd77580 042f18a0
3fff64d0: 4a867403 c099aa82 222ac12c a5f6ad1a
3fff64e0: d93a9ee3 aee42928 ee56dd91 ef680601
3fff64f0: a210b7b6 e59b7954 e4f9502f 0fe2d45c
3fff6500: 9e0fcdca 8cb5a184 70a777a8 f9f89b4f
3fff6510: 9dd2d8c9 a9d378de 8615e3af 2f95c8a8
3fff6520: d9f72f9b 641703b7 7910a5d1 dad7b9ca
3fff6530: bc1f6fcd 73b7a052 e6645f01 03808bfa
3fff6540: 298a4fc7 018e037c f500f308 d61cca51
3fff6550: cb81bebd 1553a1bf 2bccbccf 941669a1
3fff6560: 015ed32e f4c2b185 578f6d19 d6cb3708
3fff6570: 6f2ebe75 3c7b8229 72656c3b d51eecb2
3fff6580: 8dcb900e d9d4e804 5af4bfb1 3d017bf1
3fff6590: 32adad58 4d9fe91c 1cbfd192 bf1d15bc
3fff65a0: 6430fe9c 7a283f56 a2289077 7b6d6348
3fff65b0: 99e479e6 aa6df7d6 3f4e295b 056b3489
3fff65c0: 67941fd2 8b6921c1 de4b3a68 93451377
3fff65d0: 0f4e9507 6fe05207 6e11423a 1f1fcb04
3fff65e0: 4c0a727f e288107f f266ec91 d1c3efe9
3fff65f0: 0baeaf84 fde5e413 c3f0e998 d0974dc8
3fff6600: 2e16febb 66f1f1aa 98a8f01f 1b57463b
3fff6610: 34aa1332 3527140c cd10b6f4 0e6fac6b
3fff6620: aeab3aed 720ef14a ffcc06fc 225345e9
3fff6630: 38d37ab8 865d4407 da21665b 97b8d2c7
3fff6640: 65d450c5 69f31219 cc90c7de 6f2f53ba
3fff6650: 6ae6cca7 97d063b5 12020e67 02c5c48d
3fff6660: 34d76bd2 bd4f0540 5d187e77 73275fa1
3fff6670: fd07f74a 94a57025 10088ef3 693c4980
3fff6680: 36926872 ae0b0111 58bd20f2 5b2b9710
3fff6690: dad232d6 bbe96662 a54f21fd 363f3f76
3fff66a0: c79cf8f8 5151895e 4aa9e7d6 56ecf4a0
3fff66b0: e8cf89d5 3f0509f5 ecc946ca 309a4b3e
3fff66c0: 5f7640e9 63e303da 1b08fb5e 10473add
3fff66d0: ebcad256 027b2bc6 66a5f7ef 699778c9
3fff66e0: de3c535a 3f0f1444 48445ad2 7436e0ad
3fff66f0: 84941e79 21997662 fd57a6a3 e20fd16c
3fff6700: dbd5453c d98347b1 889a78a3 43d9dd72
3fff6710: 00d6ae02 fa7d5b42 4dc29e80 3bcc842d
3fff6720: e15627bf 4559f566 10914bf7 361e67eb
3fff6730: a41fed98 a4e9c852 8b5f7ab0 713c64a4
3fff6740: 30291acd 25a35745 43e0871d dfbd662a
3fff6750: 491060bb 4611c100 a79285e1 fe7e4198
3fff6760: c5bd9eab a30f629b 661cce01 11b7d9d0
3fff6770: 8489484e 18ede507 86e279e3 afe7c5a6
3fff6780: 91d50820 9c8e3a11 5567f836 ddc3988c
3fff6790: 02a15dfa 927ee43e 60827f74 4bf3cb92
3fff67a0: d6070b4e 88aaced8 daf959d8 8499de51
3fff67b0: 3fc3b660 56d5b359 70143e52 b1d206f2
3fff67c0: 1c476ec1 99eaa823 3c12b499 31045dc5
3fff67d0: 187a4af9 327f4bee 9a3fd1de 5d73620f
3fff67e0: 07292edb 8d1ee599 1aae41af 1583d40e
3fff67f0: 4a710eb4 fa2752c6 ac167e8d 5c94d428
3fff6800: ba04c117 ebcb03bd 00c22527 56cdc4c0
3fff6810: e916adaa bd63a05f a1abc5fe 72c9728f
3fff6820: f320b74c a78ed5c1 39407069 12c9b5c9
3fff6830: 98adbd0e dcdc7a5a 906a6d2b f44eb449
3fff6840:þ
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ªU
INIT : Booting Build nr:78
WIFI : No SSID!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
hmmm? to small power supply?
check again? change with another? everthing properly grounded?
hmmm, dont know more...
Do you mean powering ESP from the USB-to-serial?Barb232 wrote: if i am starting this with arduino Serial monitor it works! I have an accesspoint ESP_0
Are you using a breadboard?
What is the max. output (Amps) of your PSU?
it finally works, i had several issues:
Problem Power-Supply: it took more current than i expected
Problem GPIO 0 connection: Maybe i set the startup to LOW so i got the startup into flash mode.
BTW: i used the switch feature in the software. Wouldn't it be nice to select a "Button" feature? .. Fields: active high -> low , low -> high, Time to H-L <> L-H in mseconds
Because i used this esp-01 in my diffusor (LEDS and diffusor on) and there is a button not a switch.
Users browsing this forum: Bing [Bot] and 1 guest
