hello,
is there a possibility to get a json-output by http for a custom event triggered?
e.g.: http://192.168.10.242/control?cmd=event,poweroff
reply is "OK" - which is in nodered then not with the same nodes parseable as e.g. http://192.168.10.242/json?view=sensorupdate&tasknr=4 or http://192.168.10.242/control?cmd=GPIO,2,0
thanks.
BR
Alois
custom event trigger json output possible?
Re: custom event trigger json output possible?
Hi alois,
what json output you would like to see for a custom event since a lot can happen in an event?
when i need a html feedback i use a command like yours:
e.g.: http://<espip>/control?cmd=event,toogle
and then do another request for the response:
e.g.: http://<espip>/csv?tasknr=1&valuenr=1&header=0
(i use this for shortcuts in ios to toggle a relay..so i get the state of the relay as a feedback. in this example a simple 1 or 0)
the "OK" would be already enough output, but it is not json.
so if it would be e.g.:
"reply": "OK"
or, to be distinguishable e.g.:
"event,<eventname>": "OK"
it would be parseable with a "generic" HTTP request node in nodered where also other commands (with valid json output - see above) are fed in.
"reply": "OK"
another small issue with json-replys, is this already known?
http://192.168.10.243/control?cmd=GPIO,2,0
reply with build ESP_Easy_mega_20220328_normal_ESP8266_4M1M:
"log": ": port#2: set to 0",
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 0
while build ESP_Easy_mega_20210114 replied:
"log": "port#2: set to 0",
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 0
note the additional ": " in the beginning of "log"-string
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 0
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 0
