simplified rules Neopixel
niblon91
#1 Post by niblon91 » 13 Oct 2022, 02:27
Hi there ,
I have a staircase lighting project, with 3 LEDs per step. I'm trying to simplify the rule: in the current state, I light 1 and 3 then when they go out I light 2, when they go out I light 4 and 6 etc .... but too much line for the rules with my 48 leds
on System#Boot do
  timerSet 1,10
 On Rules#Timer=1 do
  neopixel,1,50,0,0
  neopixel,3,50,0,0
   delay 2000
  neopixel,2,50,0,0
  neopixel,1,0,0,0
  neopixel,3,0,0,0
   delay 2000
 neopixel,4,50,0,0
 neopixel,6,50,0,0
 neopixel,2,0,0,0
  delay 2000
 neopixel,5,50,0,0
 neopixel,4,0,0,0
 neopixel,6,0,0,0
  delay 2000
 neopixel,7,50,0,0
 neopixel,9,50,0,0
 neopixel,5,0,0,0
  delay 2000
 neopixel,8,50,0,0
 neopixel,7,0,0,0
 neopixel,9,0,0,0
  delay 2000
 neopixel,8,0,0,0
  timerSet 1,1
the goal will be to start it with a detector and to stop it with another detector
Thanks in advance
Niblon91
Re: simplified rules Neopixel
#2 Post by Ath » 13 Oct 2022, 09:30
So you would need something like the NeoPixelLine command that supports an interval option for on and off pixels in the range?
#3 Post by TD-er » 13 Oct 2022, 10:25
And please don't use delay in rules.
Rather use the looptimer. It does send events with an extra eventvalue representing the loop count.
N.B. you can also set the nr of loops.
See: https://espeasy.readthedocs.io/en/lates ... oop-timers
One way of reducing the amount of code is to set the leds in variables and use the loop counter as an offset
On System#Boot do    //When the ESP boots, do
  looptimerset_ms,1,2000,10  // Start loop timer 1, 2000 msec interval, 10 loops
  let,1,1
  let,2,3
  let,3,2
  let,5,4
  let,6,6
  let,7,5
On Rules#Timer=1 do
  if [int#100] != 0
    // First turn the previous ones off
    neopixel,[int#[int#100]],0,0,0
    let,100,[int#100]-1
  if %eventvalue2% != 10
    // On the last loop, don't turn the LEDs on
    let,100,%eventvalue2% * 2 // The start index based on the loop count
    neopixel,[int#[int#100]],50,0,0
    let,100,[int#100]+1
    let,100,0 // Set the index to 0 again
[code]
Then you have to initialize the other variables at boot containing the LED indices.
N.B. this code is untested.
igorka
#4 Post by igorka » 07 Nov 2022, 10:43
I'm starting to get acquainted with NeoPixel (WS2818B)...As always, there are more questions than answers.
Why does such a record work incorrectly?
On System#Boot do
let,1,120
let,2,100
NeoPixelAllHSV,let1,let2,10
I want to try such a code example as for Arduino, but I don't have enough mind yet...
#include <Adafruit_NeoPixel.h>
int pix = 30;
Adafruit_NeoPixel strip (pix, 6, NEO_GRB + NEO_KHZ800);
void setup() {
   strip.begin();
   strip.show();
   strip.setBrightness(50);
void loop() {
   for (int i = 0; i <= pix; i++) {
      strip.setPixelColor(i, 0, 0, 250);
      strip.show();
      delay(50);
   for (int b = 50; b < 250; b++) {
         strip.setPixelColor(i, 250, 250, b * i / 250);
      strip.show();
      delay(50);
#5 Post by TD-er » 07 Nov 2022, 11:23
The "let" command does set a variable.
For example "let,1,123"
This variable can then be used via [int#1] as integer or [var#1] as floating point value.
"let,2,234" will of course set variable #2.
Thus your code would then be:
On System#Boot do
  let,1,120
  let,2,100
  NeoPixelAllHSV,[int#1],[int#2],10
See: https://espeasy.readthedocs.io/en/lates ... -variables
igorka
#6 Post by igorka » 07 Nov 2022, 16:54
Thanks for the answer above!
Questions again ...
How to perform integer calculations (mathematical operations with variables)?
On System#Boot do
loopTimerSet,1,1
let,1,1
let,2,1
let,3,0
on Rules#Timer=1 do
[int#3]=[int#1]+[int#2]
And such a record does not work either...
[int#1]+1
What is my mistake, please indicate.
#7 Post by TD-er » 07 Nov 2022, 17:02
On System#Boot do
loopTimerSet,1,1
let,1,1
let,2,1
let,3,0
on Rules#Timer=1 do
let,3,[int#1]+[int#2] // perform calculations
let,1,[int#1]+1
#8 Post by Ath » 07 Nov 2022, 17:04
igorka wrote: 07 Nov 2022, 16:54 What is my mistake, please indicate.
It will help you having a look at the Rules documentation, quite some time went into writing that... ;)
igorka
#9 Post by igorka » 09 Nov 2022, 12:58
TD-er wrote: 07 Nov 2022, 17:02
let,1,[int#1]+1
Thanks for the help!Honestly, I only noticed that you replied... Fortunately for myself, I was able to find an answer on the forum, and only then read your message. Excuse me, but I have a question again...
My goal is to try to control the LEDs by Mqtt. Somewhere I make a mistake, I can't figure out where.
On Led#hu do
 logentry,"MQTT import hu: %eventvalue1%"
 NeoPixelAll,%eventvalue1%,%eventvalue2%,%eventvalue3%"
tried it like this:
On Led#saturat do
 logentry,"MQTT import saturat: %eventvalue2%"
 NeoPixelAll,[int#eventvalue1],[int#eventvalue2],[int#eventvalue3]"
tried it like this:
On System#Boot do
NeoPixelAll,0,0,0
let,1,0
On Led#hu do
 logentry,"MQTT import hu: [int#1]"
 NeoPixelAll,[int#1],[int#eventvalue2],[int#eventvalue3]"
I understand from Mqtt the digits come in string format, but you need to convert to int?
#10 Post by TD-er » 09 Nov 2022, 13:11
On System#Boot do
NeoPixelAll,0,0,0
let,1,0
On Led#hu do
You cannot nest the on...do...endon parts
Apart from that, you still need to wrap the eventvalue part in percent characters:
NeoPixelAll,[int#1],[int#%eventvalue2%],[int#%eventvalue3%]
Also you had a closing quote on that line.
But I'm not sure what you want to achieve here.
[int#%eventvalue2%] means: refer to the variable with index given as eventvalue.
So you need to have this variable set, or else you will get strange results.
igorka
#11 Post by igorka » 09 Nov 2022, 15:41
I'm sorry, I wrote some nonsense with a bunch of mistakes, it's a rush and a low level of knowledge in programming.Maybe delete my previous post?I created three variables to control the RGB tape, let,1; let,2; let,3.I need the Mqtt protocol to send values and save them to the variables let,1; let,2; let,3.
This is my attempt to do this (an example for the let,1 variable):
On System#Boot do
NeoPixelAll,0,0,0
let,1,0
let,2,0
let,3,0
On Led#hu do
 logentry,"MQTT import hu: let,3,[int#1]"
 NeoPixelAll,[int#1],[int#2],[int#3]
How to transfer values from variables hu, saturat, val to variables let,1; let,2; let,3 or directly control, something like this NeoPixelAll,[int#hu],[int#saturat],[int#val]?
#12 Post by Ath » 09 Nov 2022, 16:26
igorka wrote: 09 Nov 2022, 15:41 How to transfer values from variables hu, saturat, val to variables let,1; let,2; let,3 or directly control, something like this NeoPixelAll,[int#hu],[int#saturat],[int#val]?
You can use the values directly, every time one of the values changes:
(You will have to enable the Generate events checkbox in the MQTT Import task settings)
On Led do
  logentry,"MQTT import Hue: [Led#Hu], Sat [Led#saturat], Val [Led#val]"
  NeoPixelAllHSV,[Led#Hu],[Led#saturat],[Led#val]
If you also enable the checkbox Single event with all values, it could be like this:
On Led#All do
  logentry,"MQTT import Hue: %eventvalue1%, Sat %eventvalue2%, Val %eventvalue3%"
  NeoPixelAllHSV,%eventvalue1%,%eventvalue2%,%eventvalue3%
igorka
#13 Post by igorka » 09 Nov 2022, 16:55
Thank you, I am grateful to you for your help and time spent on me! But unfortunately your code examples don't work either, at least for me. :(
Such a rule:
On System#Boot do
NeoPixelAllHSV,0,0,0
On Led do
#14 Post by Ath » 09 Nov 2022, 17:01
Ah, that plugin doesn't send default value events, only events on receiving data, so the #All event isn't available.
You'll have to use my other example in that post using "on Led do"
igorka
#15 Post by igorka » 09 Nov 2022, 17:20
Ath wrote: 09 Nov 2022, 17:01 You'll have to use my other example in that post using "on Led do"
On Led do
On Led#All do
As you can see, the result is the same.
#16 Post by Ath » 09 Nov 2022, 21:23
igorka wrote: 09 Nov 2022, 17:20 As you can see, the result is the same.
Does it work if you use "on Led#Hu do" ?
If so, you can use an alternative like this:
(Remove any other "on Led* do" event handlers)
On updateLed do
On Led#Hu do
  AsyncEvent,updateLed
On Led#saturat do
On Led#val do
Then any updated value will be handled, and update the led-stripe
igorka
#17 Post by igorka » 10 Nov 2022, 06:26
Ath wrote: 09 Nov 2022, 21:23
Hooray works!!! You're a magician.Very complex code, I would never have thought of that.
I looked at the NeoPixel library and there in my opinion there is a convenient option for recording color:
led.setColor(0xFF00FF);
Also, I don't fully understand the color codes if you put it this way:
NeoPixelHSV,<led nr>,<hue>,<saturation>,<value>
For example, if you write the color like this, then this is as clear as possible:
NeoPixel,<led nr>,<red>,<green>,<blue>
NeoPixel,<led nr>,255,0,0//red
NeoPixel,<led nr>,0,255,0//green
NeoPixel,<led nr>,0,0,255//blue
NeoPixel,<led nr>,255,255,255//White
#18 Post by TD-er » 10 Nov 2022, 10:42
That's the difference between "color spaces"
RGB is basically how the LEDs are addressed. You have some amount of R, some of G and some B.
But to humans, this color space isn't very intuitive if you use values other than 0 or 255 for these.
So the HSV color space was designed to be more intuitive for how we humans like to make adjustments.
To start with the H (hue).
It is just some angle on the color wheel:
For example if the light is too yellow, you turn the angle either to the green side, or the red side.
The S (saturation) is a parameter to change between "less or more color".
Full saturation will be "as colorful as can be" and 0 saturation will be like a B/W photo. Only black and white and all shades of grey inbetween.
In terms of paint, this is called a "tint". (e.g. pastel tint)
The V(value) is just the amount of light.
So 0 is with the lights turned off, 255 is at maximum brightness (given the other two values H and S)
The V can somewhat be compared to typical terms used for paint, like a "tint" (pure color paint with white added) or a "shade" (pure color paint with black added).
Changing only the V is not (supposed to) change the color, but just "more or less light".
Since there has to be some conversion using a limited nr of input and output values (integer value steps), both on the HSV values and the RGB led driving values, you can see some strange artefacts when approaching the ends of the V value.
For example a nice yellow color may turn green when the V approaches 0, simply because the amount of red needed is already at its lowest possible value.
Anyway, let's not make things more complicated. Just keep in mind that color mixing with light differs from color mixing with paint. :)
#19 Post by Ath » 10 Nov 2022, 11:44
igorka wrote: 10 Nov 2022, 06:26 Also, I don't fully understand the color codes if you put it this way:
I switched to using HSV colors in my code, as your MQTT messages seem to have the HSV values, that TD-er just explained how they work, it wouldn't be correct to use the default RGB commands as then it will not match your expected colors. And the NeoPixel plugin does support HSV colors :)
igorka
#20 Post by igorka » 10 Nov 2022, 11:56
TD-er wrote: 10 Nov 2022, 10:42 Anyway, let's not make things more complicated. Just keep in mind that color mixing with light differs from color mixing with paint. :)
Of course we won’t, because you explained everything to me very sensibly!
Thank you for your help!
Ath wrote: 10 Nov 2022, 11:44
My mistake. I started experiments with HSV, and then I decided to try with RGB, but I did not change the name of the variables.
