1. Inconsistency in the RTD / TaskValueSet
In the RTD there is an inconsistency in the TaskValueSet area as to how the command is to be written.
TaskValueSet 12,1,0 versus TaskValueSet,12,1,0 respectively TaskValueSet dummy,var1,0 versus TaskValueSet,dummy,var1,0
Once it is shown with spaces, once with a comma. It may of course be that both are correct (I haven't tried it yet), but in my opinion you should urgently write if both spellings are correct.
2. Simple Rule don't work
On Clock#Time Do
TaskValueSet,6,1,%syshour%
TaskValueSet,6,2,%sysmin%
If [tick#h] > 12
TaskValueSet,6,3,[tick#h]-12
Elseif [tick#h] = 0
TaskValueSet,6,3,12
Else
Endif
Value 1 to 3 (4 I don't use yet) will not set if the time- event comes up every minute
