DS1820
stefbo
DS1820
#1 Post by stefbo » 02 May 2016, 00:34
Dear all,
I changed the Plugin_004_DS_readTemp function such that it gives also correct values for DS1820 or DS18s20 (both with family id 0x10). The code is based on the DallasTemperature-lib 3.7.3
Stefan
boolean Plugin_004_DS_readTemp(uint8_t ROM[8], float *value)
  int16_t DSTemp;
  byte ScratchPad[12];
  Plugin_004_DS_reset();
  Plugin_004_DS_write(0x55);           // Choose ROM
  for (byte i = 0; i < 8; i++)
    Plugin_004_DS_write(ROM[i]);
  Plugin_004_DS_write(0x44);
  delay(800);
  Plugin_004_DS_write(0xBE); // Read scratchpad
  for (byte i = 0; i < 9; i++)            // copy 8 bytes
    ScratchPad[i] = Plugin_004_DS_read();
  if (Plugin_004_DS_crc8(ScratchPad, 8) != ScratchPad[8])
      *value=0;
      return false;
  if(ROM[0] == 0x28 ) //DS18B20
      DSTemp = (ScratchPad[1] << 8) + ScratchPad[0];
      *value = (float(DSTemp) * 0.0625);
  else if(ROM[0] == 0x10 ) //DS1820 DS18S20
      DSTemp = (ScratchPad[1] << 11) + ScratchPad[0] << 3;
      DSTemp = ((DSTemp & 0xfff0) << 3) - 16 +
          ((ScratchPad[7] - ScratchPad[6]) << 7) /
            ScratchPad[7]
    *value = float(DSTemp) * 0.0078125;
  return true;
bennybubble
Re: DS1820
#2 Post by bennybubble » 04 May 2016, 11:37
Great job, I've been waiting for this for a long time !
Are you planning to incorporate this into GITHUB so everybody can benefit ?
-ben
tozett
Re: DS1820
#3 Post by tozett » 07 May 2016, 13:19
hello Developer,
could you inform us (here, and/or in the changelog), if you adopted this bugfix/ehancement?
(topic was on the wishlist...)
thankx ;) :D
Martinus
Re: DS1820
#4 Post by Martinus » 08 May 2016, 14:18
tozett wrote:hello Developer,
thankx ;) :D
Will be added in R106
bennybubble
Re: DS1820
#5 Post by bennybubble » 09 May 2016, 09:32
Thanks !
Users browsing this forum: Bing [Bot] and 13 guests
