Neopixel Battery Gauge ?
chr2002_2
#1 Post by chr2002_2 » 24 Sep 2023, 12:25
Can ESPeasy show a battery gauge on a Neopixel ring ?
Can this be done by a Rule ?
I want to read a 0-100 (%) Value using MQTT_Import and visualize the Value with a Neopixel Ring on e.g. 40 LEDs with coloring from red (low battery) over yellow (medium charge) to green (nearly full / full charge)
Is this possible with espEasy ?
Greetings Chris
Re: Neopixel Battery Gauge ?
#2 Post by TD-er » 24 Sep 2023, 12:42
We do support some battery gauge chips, like these: https://espeasy.readthedocs.io/en/lates ... 5-typename
So using rules, you should be able to turn it into a NeoPixel command to update the number of LEDs on your ring and also set the color if you like.
chr2002_2
#3 Post by chr2002_2 » 24 Sep 2023, 14:21
Ah, i saw this feature,
But I want to monitor my PV Battery. Its a 9,6 KWh Battery system. The Inverter reports a value 0 - 100 via Modbus to my MQTT Broker.
I think, its not as easy zu visualize / scale this value on a Neopixel Ring.
#4 Post by Ath » 24 Sep 2023, 15:07
You can configure the MQTT Import plugin (name: MQTTImport) to receive that value, and name that value BatteryPercentage, enable that task and add this to the rules:
on MQTTImport#BatteryPercentage do
  let,1,40 // Number of LEDs
  let,2,%eventvalue1%/(100/%v1%) // Number of LEDs to light up
  if %eventvalue1%<15
    NeoPixelLine,1,[int#2],255,0,0 // Red
  elseif %eventvalue1%<85
    NeoPixelLine,1,[int#2],255,127,80 // Orange (coral)
    NeoPixelLine,1,[int#2],0,255,0 // Green
This assumes you have the NeoPixel (Basic) plugin configured and enabled, so these commands can work.
You can determine the max. brightness using the plugin settings. This may alter the actual color unexpectedly if the brightness is (very) low, as it uses integer division to calculate a new value per color.
NB: Air code :D
chr2002_2
#5 Post by chr2002_2 » 28 Sep 2023, 18:58
I had to add some lines, to clear the LEDs.
Otherwise the "consumed LEDs" keep on.
on MQTT_W#PV_CAP_BAT do
let,1,24 // Number of LEDs
if %eventvalue1%<25
NeoPixelLine,[int#2]+1,25,0,0,0 // clear/poweroff consumed LEDs
NeoPixelLine,1,[int#2],100,0,0
NeoPixelLine,1,[int#2],58,74,0
NeoPixelLine,1,[int#2],0,100,0
#6 Post by Ath » 28 Sep 2023, 22:21
chr2002_2 wrote: 28 Sep 2023, 18:58 I had to add some lines, to clear the LEDs.
Ah, yes, didn't think of that :oops:
A few minor corrections:
  if %eventvalue1%<25
    NeoPixelLine,[int#2]+1,[int#1],0,0,0  // clear/poweroff consumed LEDs
Using the set number of LEDs "[int#1]" to clear to the end instead of the fixed (and AFAICS wrong) number 25.
