cannot save rules and GUI is odd
I run a SONOFF S26 .
I cannot save the rules and the GUI seems incomplete. It shows "saved" even before saving anything , after a factory reset.
I have configured this S26 several months ago and I don't remember having any issue with it.
After several unsuccessful tries, I have decided to make a factory reset. It has not changed anything, same problem.
One more display What would be your advice? Reopen the S26 , solder again and reload a new copy of the firmware ?
Let me know if you need more info. ( I get nothing in the LOG file ('log error ' setting)).
- 1.JPG (62.98 KiB) Viewed 16011 times
Re: cannot save rules and GUI is odd
Added a notify to be alerted in case of answer.
Something changed at the CDN-supplier for providing the .css and .js files, breaking some UI stuff on ESPEasy side. This has been corrected.
You can upgrade to the latest ESPEasy release to solve the issue.
Thanks for your explanation.
I suppose I can't upgrade using wifi so I need to reopen the Sonoff S26 and solder the cables again
The S20 was easier to upgrade.
Gilles
Gilles
Does the S26 have an accessible flash chip?
If so, then you might want to consider also upgrading this flash chip to a 4M variant so you never need to open up the enclosure again.
I will check and order it if I think that I am able to make it.
I suppose that I have to first flash the new one before solder it on the S26. So can I use the "blank_4MB.bin".
I have found a link which explains: Sonoff S26 EEPROM Upgrade – MakeNotes.de but I am not sure to understand everything.
Thanks for the 4M tip.
That link doesn't work, it should go here: https://makenotes.de/2019/05/sonoff-s26-eeprom-upgrade/
Hi Ath,
Sorry, I have posted a wrong url. But I was talking about the same .
Hi Ath,
you were right.
I have just upgraded the Sonoff S26 to the "ESP_Easy_mega_20231225_normal_ESP8266_1M" version and now , everything looks fine.
NB: just one thing, Now, I must tick the Device "Inversed Logic". It was not ticked with the former version.
Thanks again
Gilles
you were right.
Thanks again
Gilles
Not sure what you are trying to say here I don't see mentioned any setting above, so I don't understand what you are trying to set to "Inversed Logic".
With the December espeasy version, I need to tick the "inversed logic" option at t he device level. If I don't, when the S26 is switched on, the bulb connected to it is switched on as well.
Here is the december version screen . Look at the yellow part. Before the upgrade, I didn't need to tick this option to avoid the bulb to be switched on at startup.
But the S26 only has a push button right?
So why use the switch type set to "Switch" here and not as "push button" ?
Now you need to keep the button pressed to keep it "active"
What old version of ESPEasy was installed, before you upgraded to the August 2023 release, as the August version also must have had this behavior.
I have a S26 that I have just upgraded ( see above). Once upgraded , I have copied the configuration of the S20. I use both to switch on/off heaters using wifi.
I don't use the S2x button. The S20 runs
I trigger it with "192.168.1.60/control?cmd=event,AL" , it starts a timer (1 hour) . When the timer expires, it switches off the S2x.
along with these rules:GIT version: v2.0-20180126
On ET do
gpio,12,0
gpio,13,0
TimerSet,8,0
EndOn
On AL do
gpio,12,1
TimerSet,8,3600
EndOn
On Rules#Timer=8 Do
gpio,12,0
gpio,13,0
EndOn
I don't see how the switch (button) task is interacting with the relay given the rules.
So I don't know why you now need to have the inverse logic checked.
It is hard to tell what specifics may have changed in the last 6 years to change this behavior
You are right, there are some other rules to make the button work.
I usually don't use the button.
I use the wifi (http://192.168.1.118/control?cmd=event,AL) to switch on the heater(which is in the basement) during my breakfast, so when then I go downstairs to the basement to work, the temperature is nice
One hour later, it is automatically switched off.
Users browsing this forum: Bing [Bot] and 0 guests
