esp01 dht22
BartSr
esp01 dht22
#1 Post by BartSr » 23 Apr 2024, 18:11
Hi, is there a binfile for using esp01 together with humidity sensor dht22
Re: esp01 dht22
#2 Post by Ath » 23 Apr 2024, 19:59
In the list of plugins you can see that this plugin is in the Normal plugin set, implying it's available in nearly all builds. For 1MB ESP8266 units, like the ESP01, there is a Normal 1M (_not_ 4M1M !) build available that you can upload.
Re: esp01 dht22
#3 Post by TD-er » 23 Apr 2024, 20:20
Keep in mind this is for 1M flash and cannot be upgraded via the web interface, only flashed via serial.
The reason I mention this is that there are ESP01 and ESP01S boards.
The latter one has 1M flash, according to this thread
BartSr
Re: esp01 dht22
#4 Post by BartSr » 23 Apr 2024, 20:52
Thanks,
I looked into https://td-er.nl/ESPEasy/
but from there I might have overlooked but anyway, couldnot find a binfile .
So I did it the old-fashione dway now :-)
'problem' solved
Re: esp01 dht22
#5 Post by Ath » 23 Apr 2024, 20:58
BartSr wrote: 23 Apr 2024, 20:52 I looked into https://td-er.nl/ESPEasy/
It's there:
Screenshot - 23-04-2024 , 20_59_28.png (7.47 KiB) Viewed 553 times
BartSr
Re: esp01 dht22
#6 Post by BartSr » 23 Apr 2024, 21:09
mmm.... thought about spiff is something special....
sorry and thanks again
