Adding pins for softwareserial for ser2net
Woodster
#1 Post by Woodster » 18 Aug 2016, 12:42
Hi there,
what about using two pins for software serial for attaching an esp8266 running ser2net - Then the normal USB connection would always work?
Martin
Justblair
Re: Adding pins for softwareserial for ser2net
#2 Post by Justblair » 18 Aug 2016, 14:11
There already are pins broken out for serial on the Arduino D0 and D1 You should be able to connect to them surely? Just be sure to add a signal converter to take the serial lines from 5v to 3.3v. I did read somewhere that the ESP8266 is 5v tolerant (despite the documentation) so you could try without.
Woodster
#3 Post by Woodster » 18 Aug 2016, 14:57
Hi there,
yes I know - but then the built in USB/Serial might not work - the esp8266 might need to be removed during upgrade.
It does not need to be a software port, a hardware port could be used as well. .
If it is placed somewhere else, then the firmware just needs to forward the frames to the port also.
