Can you please have a look at this device.?
http://nl.aliexpress.com/item/Free-ship ... 77124.html
rflink translates it as a eurodomest and sometimes as an ev1527...
I can send you the debug info if needed.
door sensor saful ts-5517
Re: door sensor saful ts-5517
Yes, please send a debug log.. we are currently implementing some changes to the detection of Eurodomest/EV so we can look at this one as well..
20;38;DEBUG;Pulses=50;Pulses(uSec)=240,810,780,210,180,810,180,780,780,210,180,780,180,810,780,210,810,210,780,210,180,780,780,210,180,810,180,810,810,210,180,810,180,810,780,210,180,810,780,210,180,810,780,210,780,210,180,810,180,6990;
20;39;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;3A;DEBUG;Pulses=50;Pulses(uSec)=210,810,810,210,180,810,210,810,810,210,180,810,180,810,810,210,810,210,810,210,180,810,810,210,210,810,210,810,810,210,180,810,180,810,810,210,210,810,810,210,210,810,810,210,810,210,210,810,210,6990;
20;3B;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;3C;DEBUG;Pulses=50;Pulses(uSec)=270,840,900,210,210,810,210,810,900,240,210,810,210,810,900,240,900,240,870,240,210,810,900,240,210,810,210,810,900,240,210,810,210,810,900,240,210,810,900,240,210,810,900,240,900,240,210,810,210,6990;
20;3D;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;3E;DEBUG;Pulses=50;Pulses(uSec)=300,840,1080,270,240,840,240,840,1050,270,240,840,240,840,1080,270,1050,270,1050,270,240,840,1050,270,240,870,240,840,1050,270,240,840,240,840,1050,270,240,840,1050,270,240,840,1050,270,1020,270,240,840,240,6990;
20;3F;EV1527;ID=049d25;SWITCH=06;CMD=ON;
20;40;DEBUG;Pulses=50;Pulses(uSec)=360,900,1320,330,270,930,300,900,1410,360,300,900,330,900,1530,330,1560,330,1650,330,360,930,1740,330,390,930,390,930,1860,330,420,930,450,930,1980,360,450,930,2070,360,480,930,2130,360,2190,360,540,990,540,6990;
20;41;DEBUG;Pulses=50;Pulses(uSec)=240,810,780,210,180,780,180,810,780,210,180,810,180,810,780,210,780,210,780,210,180,810,810,210,180,810,180,810,780,210,180,810,180,810,780,210,180,810,780,210,180,810,780,210,780,210,180,810,180,6990;
20;42;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;43;DEBUG;Pulses=50;Pulses(uSec)=210,810,810,210,210,810,210,810,810,210,180,810,210,810,810,210,810,210,810,210,180,810,810,210,210,810,210,810,810,210,210,810,180,810,840,210,180,810,810,210,210,810,810,210,810,210,210,810,210,6990;
20;44;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;45;DEBUG;Pulses=50;Pulses(uSec)=270,840,870,240,210,840,210,810,900,240,210,810,210,810,900,240,900,240,900,240,210,810,900,240,210,810,210,810,900,240,210,840,210,810,900,240,210,810,900,240,210,810,900,240,900,240,210,810,210,6990;
20;46;Eurodomest;ID=0b62da;SWITCH=03;CMD=OFF;
20;47;DEBUG;Pulses=50;Pulses(uSec)=330,840,990,240,240,840,240,840,990,240,240,810,240,840,990,240,990,240,990,240,240,840,990,240,240,840,240,840,990,240,240,840,240,840,990,240,240,840,990,240,240,840,990,240,990,240,240,840,210,6990;
20;48;EV1527;ID=049d25;SWITCH=06;CMD=ON;
20;49;DEBUG;Pulses=50;Pulses(uSec)=300,840,1050,270,240,840,240,840,1050,270,240,870,240,840,1080,270,1050,270,1050,270,240,870,1050,270,240,840,240,840,1050,270,240,870,240,870,1050,270,240,840,1050,270,240,870,1020,270,1020,270,240,870,240,6990;
20;4A;DEBUG;Pulses=50;Pulses(uSec)=270,870,870,270,180,870,180,870,900,270,210,870,210,870,900,300,900,330,900,300,180,900,930,300,180,870,210,870,990,330,180,870,240,870,1020,300,210,870,1050,330,210,870,1080,330,1080,300,240,870,240,6990;
20;4B;DEBUG;Pulses=50;Pulses(uSec)=690,960,2490,360,630,990,660,990,2610,360,690,990,690,990,2760,360,2850,360,2940,360,810,990,3060,360,840,990,840,1020,3270,360,930,1020,930,1020,3540,390,990,1050,3810,390,1110,1050,4110,390,4410,390,1320,1080,1320,6990;
Thanks.. we will check it out!
Users browsing this forum: Ahrefs [Bot] and 0 guests
