Sonoff 4CH with ESPEasy
Re: Sonoff 4CH with ESPEasy
I have a 5-32v Sonoff/Itead 4ch, but i cant figure out how to flash it. I have flash many types of Sonoff's, i have Sonoff POW, normal 1ch Sonoffs and bulbs... I have triede both thrue my Arduino to flash it and also tried to erase it with ESP_Basic_Flasher... I always get cant open the port. Anyone triede or have any suggestions?
Are you sure this is a Sonoff 4CH? It looks totally different from the two units I have. I see no buttons, for example.
Also, my Sonoff has a mains connection from which it feeds. Looks like this one expects an external power supply!
Definitely that is not a genuine Itead 4ch.
Anyways an interesting module.
Do you have a link or schematics?
I'm not able to identifythe cpu module, it might contain an esp, not sure.
It might contain a signal cpu too.
A picture of the external casing might help, plus an accurate type/model number.
I bought true banggoodhttps://www.banggood.com/USB-5V-Or-DC-7 ... 84201407E9
That was back in may, i can see now that they have changed the product name to Geekcreit. It still uses Sonoff's app. But i would like to control it my self with mqtt
maybe just the WiFi module is from itead --> https://www.itead.cc/psb-04.html
It's a different chip, psf-b85 https://www.itead.cc/wiki/File:Pins_map_PSF-B85.png
So i'll try flashing it, all the pins i need is on one sideof the pcb...
I did'nt, i think the image is from the pcb side, and i think i was right, i just found this image
It worked
Its a 8266 chip and works perfect as a Sonoff 4ch PRO module
Ah, cool! I will order one to test Thanks.
(AliExpress link: http://s.click.aliexpress.com/e/eYfIy76)
Which device is that? It's not the 4ch switch showed above, isn't it?stofakiller wrote: ↑26 Sep 2017, 17:34 I did'nt, i think the image is from the pcb side, and i think i was right, i just found this image
It's the "Successful Case" explained here:
A ton of itead based OEM modules are found here: http://s.click.aliexpress.com/e/vJMNjuj
No, it's this one, frome my earlier post here viewtopic.php?f=5&t=2616&p=19423#p19212Shardan wrote: ↑29 Sep 2017, 13:11Which device is that? It's not the 4ch switch showed above, isn't it?stofakiller wrote: ↑26 Sep 2017, 17:34 I did'nt, i think the image is from the pcb side, and i think i was right, i just found this image
And i flashed it with Tasmota firmware https://github.com/arendst/Sonoff-Tasmota
Due to the PCB layout shown in the itead link this circuit uses a serial MCU to drive relays and key inputs.grovkillen wrote: ↑29 Sep 2017, 13:29It's the "Successful Case" explained here:
You can see the 20-pin square chip in the upper right corner and you can follow the "relay" pcb lines.
There are a lot of "NC" connectors - NC usually says "not connected" but obviously they are.
So this is questionable with ESPEasy.
If it uses the serial MCU it might run into same problems as the Sonoff dual.
If some of the "NC" pins are connected to usual GPIO and used by the circuit it might work.
PS: PSF-B85 and PSB-04 seem to be different ...
PSB-04 uses a serial MCU as mentioned above and uses an ESP-8266.
Datasheet: https://www.itead.cc/wiki/PSB_Series_Sm ... tch_Module
PSF-B85 seems to be a ESP-8285 based equivalent to an ESP-12 module,
1MB built in Memory and other pinout and no additional MCU
Datasheet: https://www.itead.cc/wiki/File:Psf_03.jpg
So those 4ch with a PSF-B85 should work easily with ESPEasy, might be necessary to use a ESP-8285 compiled binary.
stofakiller wrote: ↑29 Sep 2017, 11:55 It worked
Please a step by step?
Or link where i do the same thing....
My 4channel is online only i cannot use the channels...
Thanks for looking into it Shard.Shardan wrote: ↑29 Sep 2017, 14:52Due to the PCB layout shown in the itead link this circuit uses a serial MCU to drive relays and key inputs.grovkillen wrote: ↑29 Sep 2017, 13:29It's the "Successful Case" explained here:
Screen dump of AliExpress picture. Seems to be genuine ESP.
https://www.dropbox.com/s/yo9wk6ibx1ia3 ... 0.png?dl=0
You found how to flash it but haven't reported back about it. Me and a friend flashed this unit plus the smaller one, with on relay, today. Will try to write an official wiki page for it soon.stofakiller wrote: ↑21 Sep 2017, 15:07 Hi,
Nowadays
accounts have become popular among people around the World more than ever before.https://logmein.site wrote:gmail login
This unit is now "officially" supported by ESP Easy: https://www.letscontrolit.com/wiki/inde ... ff_DIY_4chstofakiller wrote: ↑21 Sep 2017, 15:07 Hi,
Any chance of formal support for the Sonoff Pow? Looks like a very handy little device to help understand power consumption...
Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
There's already a long thread about sonoff pow in the forum.
http://www.letscontrolit.com/forum/view ... POW#p20950
I noticed, and managed to read half way through it.Shardan wrote: ↑12 Dec 2017, 20:10There's already a long thread about sonoff pow in the forum.
At some point the discussion drifted off towards liability and how people will try to electrocute themself.
I was hoping to find a firm "yes" or "no" answer to the support question, or (if that can't be given) perhaps a careful "maybe in the near future"...
Ah, yes...grovkillen wrote: ↑12 Dec 2017, 17:04Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
Unfortunately I am more of a tester than a developer these days... I'm sure I would eventually even be able to write a plugin, but the learning curve would be a bit steep!
But you can always do something, like finding places where to find more information etc. Links are valuable assets.manjh wrote: ↑12 Dec 2017, 20:48Ah, yes...grovkillen wrote: ↑12 Dec 2017, 17:04Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
What do you mean? I already wrote a plugin to support POW current/voltage reading feature.
The relay and led can be activated with standard plugin, what else you need?
you just made my day!
This information is probably somewhere in the seond half of that long thread, which I have not read yet. I also checked the Wiki, found a number of Sonoff products that are supported but did not see any reference to the pow.
Can I assume the plugin is in Github?
Yes, it's in the playground still but fully functional...manjh wrote: ↑13 Dec 2017, 08:45you just made my day!
Great. Now I will have to figure out how to get it from that "playground", and compile....papperone wrote: ↑13 Dec 2017, 17:34Yes, it's in the playground still but fully functional...manjh wrote: ↑13 Dec 2017, 08:45you just made my day!
For the time being, I am using the Sonoff with their app. Works great, but not integrated with other devicecs via Domoticz.
I have managed to operate the sonoff 4ch correctly, with ESP, what I do not get is that none of the physical buttons work.
You need to create rules for that.
Example:
On TurnOn1 do
gpio, 12, 1
On TurnOff1 do
gpio, 12, 0
On TurnOn2 do
gpio, 5, 1
On TurnOff2 do
gpio, 5, 0
On TurnOn3 do
gpio, 4, 1
On TurnOff3 do
gpio, 4, 0
On TurnOn4 do
gpio, 15, 1
On TurnOff4 do
gpio, 15, 0
on Toggle1 do
if [relais1#state]=1
Event TurnOff1
Event TurnOn1
on Toggle2 do
if [relais2#state]=1
Event TurnOff2
Event TurnOn2
on Toggle3 do
if [relais3#state]=1
Event TurnOff3
Event TurnOn3
on Toggle4 do
if [relais4#state]=1
Event TurnOff4
Event TurnOn4
on button1#state do
Event Toggle1
on button2#state do
Event Toggle2
on button3#state do
Event Toggle3
on button4#state do
Event Toggle4
sorry ..., I had not restarted the sonoff.
now it works, but only the first time it turns on and off, then I press the button and it does not do anything
this is the rule
On Channel1#Switch do
if [Channel1#Switch]=1
event,Channel1_On
event,Channel1_Off
On Channel2#Switch do
if [Channel2#Switch]=1
event,Channel2_On
event,Channel2_Off
On Channel3#Switch do
if [Channel3#Switch]=1
event,Channel3_On
event,Channel3_Off
On Channel4#Switch do
if [Channel4#Switch]=1
event,Channel4_On
event,Channel4_Off
on Channel1_On do
gpio,12,1
inputswitchstate 0,1
on Channel1_Off do
gpio,12,0
inputswitchstate 0,0
on Channel2_On do
gpio,5,1
inputswitchstate 9,1
on Channel2_Off do
gpio,5,0
inputswitchstate 9,0
on Channel3_On do
gpio,4,1
inputswitchstate 10,1
on Channel3_Off do
gpio,4,0
inputswitchstate 10,0
on Channel4_On do
gpio,15,1
inputswitchstate 14,1
on Channel4_Off do
gpio,15,0
inputswitchstate 14,0
What version of ESPeasy?
I recently (last week) fixed an issue with the switch plugin.
In the first piece of code, you're checking on the state of the switch. Should be the state of the gpio.
I just put the last update today, I'll try it
nothing, with the new update they do not work either
Is there an IO-mapping for the Sonoff 4CH PRO available?
Thanks for help...
Thanks for help...
in the end I got it, thanks
at first pressing the button would turn on, but turning it off at the time it was turned on again.
After several tests I got it to work changing "normal switch" to "push button active low"
these are the rules that you create
now all switch works fine, I just need to try it with my veraedge
on Boton1#Switch do
if [Boton1#Switch]=1
gpio,12,0
gpio,12,1
on Boton2#Switch do
if [Boton2#Switch]=1
gpio,5,0
gpio,5,1
on Boton3#Switch do
if [Boton3#Switch]=1
gpio,4,0
gpio,4,1
on Boton4#Switch do
if [Boton4#Switch]=1
gpio,15,0
gpio,15,1
I tried to find the GPIO IO-mapping for the 4CH Pro using HTTP commands. At GPIO-6 relay one got on but I could not switch it off again. Tried also to switch on GPIO 4 and 5. Then I could not connect to the GUI any more and now the 4CH Pro is in a boot-loop:
When I change the onboard "Work Mode Switch" from "Interlock" to "Self-locking/Inching" it's still in a loop but the boot mode changes to (3,2). Also the top 3 LED are on.
Installed software v2.0-20180123, no change.
What to do? Is there a "GPIO of death"?
Thanks for some help.
INIT : Booting version: v2.0-20180120
INIT : Cold Boot
FS : Mounting...
FS : Mount successful, used 75802 bytes of 113201
INIT : Free RAM:26000
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_water_0 with address 192.168.4.1
WIFI : Connecting XXXX attempt #1
WIFI : Connected! IP: 192.168.10.35 (ESP_water_0)
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
INIT : Warm boot #1
FS : Mounting...
INIT : I2C
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
Sonoff 4CH Pro:
GPIO mapping is the same. All K5 switches should be set to "on", the S6 switch to 1. Then it works like the standard one.
Hello All,
I have this scheme wiring: http://prntscr.com/i0qrfb
I used homebridge plugin and iphone app HOME and I have problem about inform state.
Example:
1. State Lights on HOME app is OFF.
2. Turn on Lights with HOME app on R1 relay, snd Sonoff PRO switch reley and Lights is ON. On app HOME change state to ON.
3. When I pressing physical key "WALL SWITHC" Disconnect Electric Cricuit and turn off Light.
State continue ON on HomeAPP.
How to inform app that state is change?
Is there firmware has this possibility?
Rade
Example:
Rade
