Button event is issued when you save settings with status reset to 0
Posted: 27 Feb 2024, 20:13
Hello all,
I'm trying to configure Rules to achieve what I'll describe below, and while doing that I found a strange behavior that I want to confirm. I'm using a sonoff basic r2, with mega-20231225 and my goals are:
Now for the problem:
If I go to the configuration interface, go to the Devices tab, and EDIT my button, and then click Submit (it does not matter if I change anything), as soon as I submit it, the relay changes state. I didn't expect that.
Looking the logs, it seems like every time I save configs, the Button instance (Task) is completely re-initialized, its state goes immediately back to 0 (no matter what it was before) and a new EVENT of Button#state=0 is emitted, causing that code to trigger and toggle the relay. You can see it below:
All of this log appeared as soon as I clicked Submit, without touching the button or sending any API calls. And that "EVENT: Button#State=0" did trigger the rule and the relay toggled. This is very dangerous, it is very easy for someone to try to save settings while the relay is in use. Is this intentional? What am I missing?
I tried all sorts of black magic using variables to save old state and try to check if it was a real state change but in the end nothing I did could cover all the cases. I appreciate any hints.
Andre
- I want to be able to toggle a relay when I press the button.
- I want to be able to toggle that same relay over the web api calls (which I'm doing and works fine, using cmd=gpio,12,x).
- I want the button to keep toggling the relay even if the state was previously changed via web.
- The button is a Push Button Active Low and it's state changes between 0 and 1 at each press, as expected.
on Button#state do
GPIOToggle,12
1339335: EVENT: TaskExit#Button=1,0
1339392: EVENT: TaskInit#Button=1,1
1339400: EVENT: Button#State=0
1339408: ACT : GPIOToggle,12
1339411: GPIO toggle: port#12: set to 1
1340157: EVENT: Clock#Time=Tue,19:05
Andre
