Rules and Dummy Device
Posted: 03 Mar 2024, 10:10
by nosehook
I am a bit new in Rules and am trying the following:
Via the call
http://192.168.50.34/control?cmd=TaskValueSet%204,1,1 I want to set a dummy device (Name: DummySwitch, output data type: switch, value 1 name: Dummy) to 1.
So far, this works.
Furthermore, I want to automatically set the value back to 0.
I tried to do this via rules with several options like:
on DummySwitch do
TaskValueSet 4,1,0
So far, this does not seem to work. Apparently I am not using the right syntax or terms.
What am I doing wrong?
Thanks in advance!
Re: Rules and Dummy Device
Posted: 03 Mar 2024, 13:43
by Ath
nosehook wrote: ↑03 Mar 2024, 10:10
on DummySwitch do
TaskValueSet 4,1,0
- Have you seen the "Event: DummySwitch#Dummy=1" appear in the log output?
- Do you have other rules defined that handle "on DummySwitch#Dummy do" (optionally with =0 or =1 attached)?
Posted: 03 Mar 2024, 18:58
If you name the task "Dummy" and the taskvalue is called "Switch", then the event will be "Dummy#Switch=...." with on the dots a taskvalue.
Or if you checked to send all values in a single event, the event will be "Dummy#All=...,...,..." with comma separated the different task values (or just 1 if the task has only a single taskvalue)
Just keep in mind the "All" them.
So better keep an eye on the logs when you expect an event as the full event will be shown in the (loglevel: Info) logs.
Posted: 03 Mar 2024, 21:19
by Ath
Ah, the case with the Dummy plugin is that it doesn't generate events (after the initial event when started) when the Interval is set to 0.
So if you need a an event to be generated, you should use another member of the TaskValueSet command family: TaskValueSetAndRun:
On remoteSwitch Do
TaskValueSetAndRun,DummySwitch,Dummy,%eventvalue1% // If no argument is provided, 0 is used, and the value is sent to controllers & rules
LogEntry,'==> DummySwitch is set to %eventvalue1%'
On DummySwitch Do
TaskValueSet,DummySwitch,Dummy,0
LogEntry,'==> DummySwitch is reset to 0'
A few more remarks:
- It's more universal to use the Taskname/Valuename for setting a Dummy Device, so the code is more portable, and not bound to a specific task number
- It's better to use an Event, and a matching event-handler in rules, to change a device value from an external source, to make it more of a 'black box', and easier to change. Also, in rules you can use multiple commands for a single event, if needed (like the logentry I added)
The external command would then be:
http://192.168.50.34/control?cmd=event,remoteSwitch=1 (your browser could change that to: cmd=event%2CremoteSwitch%3D1)
Posted: 10 Mar 2024, 20:40
by nosehook
Thank you! That clarifies the issue. Much appreciated!
Ath wrote: ↑03 Mar 2024, 21:19
On remoteSwitch Do
On DummySwitch Do
A few more remarks:
