P1#Data not Published
Posted: 30 Mar 2024, 17:16
by sincze
Build: ESP_Easy_mega_20240325_collection_C_ESP8266_4M1M Mar 25 2024
So I started some experimenting with the "Communication - Serial Server"
It acts as an interface between Domoticz and the P1 meter.
After reading through the forum I noticed the extended possibility to enable:
This allows me to publish the RAW data to MQTT via the rule:
on !Serial* do // Include * to process string values
Publish,ESP_Easy/%sysname%/P1,%eventvalue%
That worked nice, however when I try
EventProcessing; "P1 Wifi Gateway"
and
P1 #date event with message (true)
I am unable to publish the data.
However the EspEasy log shows:
Smartmeter#Data=/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240330165651W),0-0:96.1.1(4530303930303030373331343231333233),
So I thought the following rule should also do the trick:
on !Smartmeter#Data* do
logEntry,"Serial1"
Even tried
and
but no data gets published.
What did I miss??
Re: P1#Data not Published
Posted: 30 Mar 2024, 17:56
by Ath
sincze wrote: ↑30 Mar 2024, 17:16
and
logEntry,"Serial1"
Even tried
and
What did I miss??
Handling P1 data is best done using P044, the P1 WiFi gateway. That's essentially the same as using P020 Serial Server (they share ~98% of the code), but P044 has some optimizations for handling P1 data, like a larger receive-buffer. Don't forget to set the RX Receive timeout at 2 or 3 msec, but you seem to have that covered
When using an ESP8266, you may run out of memory (RAM) when receiving large messages like P1 data, so it may work better when running this on an ESP32-type unit.
%eventvalue% is an alias for %eventvalue1% for backward compatibility, so maybe it's not what you expected? To get all arguments, passed to the event handler, you should use %eventvalue0%
To have an event accepted with a non-numeric first argument like the P1 data, you will need to add an asterisk in the
handler definition.
To see what's actually handled by the rule, you can add:
Posted: 01 Apr 2024, 18:41
by sincze
Ath wrote: ↑30 Mar 2024, 17:56
Ah I did not go for the P044 as the info here states the following:
https://espeasy.readthedocs.io/en/lates ... /P044.html
This plugin is now merged (back) into Communication - Serial Server where it initially was forked off from, with using some predefined settings.
So I guessed no to use that one anymore.
I can try your other suggestions
Posted: 01 Apr 2024, 18:57
by sincze
Ok with the help provided earlier this is the initial setup that works:
// logEntry,"Serial1"
Provides the following data
178599454: EVENT: !Serial#/CTA5ZIV-METER^^^^1-3:0.2.8(50)^^0-0:1.0.0(240401184851S)^^0-0:96.1.1(4530303930303030373331343231333233)^^1-0:1
178599474: ACT : Publish,ESP_Easy/Watermeter/P1,!Serial#/CTA5ZIV-METER^^^^1-3:0.2.8(50)^^0-0:1.0.0(240401184851S)^^0-0:96.1.1(45303039303
Modified the rules part and trying to publish:
On Smartmeter#Data* Do"
LogEntry,'Data: %eventvalue0%'
Publish,ESP_Easy/%sysname%/P2,%eventvalue0%
178666864: Ser2Net: Client connected!
178666877: EVENT: Smartmeter#Client=1
178667010: EVENT: Smartmeter#Data=/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401184959S),0-0:96.1.1(4530303930303030373331343231333233),1-
178667023: ACT : '
178668116: EVENT: Smartmeter#Data=/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401185000S),0-0:96.1.1(4530303930303030373331343231333233),1-
178668283: ACT : '
Nothing seems to get published.
Posted: 01 Apr 2024, 19:12
by Ath
What's that character right after the "Do" ? Looks like that doesn't belong there
Posted: 01 Apr 2024, 19:59
by sincze
Ath wrote: ↑01 Apr 2024, 19:12
Sometimes I feel a bit stupid
Publish,ESP_Easy/%sysname%/P1,%eventvalue0%
Result in the log:
182691391: ACT : Publish,ESP_Easy/Watermeter/P1,/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401195703S),0-0:96.1.1(45303039303030303733313
182692464: EVENT: Smartmeter#Data=/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401195704S),0-0:96.1.1(4530303930303030373331343231333233),1-
182692479: ACT : LogEntry,'Data: /CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401195704S),0-0:96.1.1(4530303930303030373331343231333233),1-
182692487: Data: /CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401195704S),0-0:96.1.1(4530303930303030373331343231333233),1-0:1.8.1(003492.34
Mosquitto shows only: ESP_Easy/Watermeter/P1
The rest of the info seems not to be there at all.
Posted: 01 Apr 2024, 20:20
by Ath
Better use like this:
Publish,ESP_Easy/%sysname%/P1,'%eventvalue0%'
(adding quotes around the data part)
I assume the parser stumbles over the empty argument (double comma), and stops parsing the rest of the line, while it's
supposed to also return the rest of the data. Wrapping in quotes avoids all that.
Posted: 01 Apr 2024, 20:30
by sincze
Ath wrote: ↑01 Apr 2024, 20:20
Djeez you are literary spoon feeding the solution
to me.
It worked.
There is really a lot of unseen action going on in the background.
/CTA5ZIV-METER,,1-3:0.2.8(50),0-0:1.0.0(240401202652S),0-0:96.1.1(4530303930303030373331343231333233),1-0:1.8.1(003493.095*kWh),1-0:1.8.2(001754.853*kWh),1-0:2.8.1(000295.133*kWh),1-0:2.8.2(000729.567*kWh),0-0:96.14.0(0001),1-0:1.7.0(02.607*kW),1-0:2.7.0(00.000*kW),0-0:96.7.21(00013),0-0:96.7.9(00010),1-0:99.97.0(4)(0-0:96.7.19)(230922112108S)(0000004157*s)(230918162050S)(0000000339*s)(230822142827S)(0000000214*s)(230801123219S)(0000002519*s),1-0:32.32.0(00000),1-0:52.32.0(00000),1-0:72.32.0(00000),1-0:32.36.0(00014),1-0:52.36.0(00009),1-0:72.36.0(00012),0-0:96.13.0(),1-0:32.7.0(236.0*V),1-0:52.7.0(237.0*V),1-0:72.7.0(235.0*V),1-0:31.7.0(001*A),1-0:51.7.0(001*A),1-0:71.7.0(009*A),1-0:21.7.0(00.085*kW),1-0:41.7.0(00.251*kW),1-0:61.7.0(02.274*kW),1-0:22.7.0(00.000*kW),1-0:42.7.0(00.000*kW),1-0:62.7.0(00.000*kW),0-1:24.1.0(003),0-1:96.1.0(4730303732303034323130343432323232),0-1:24.2.1(240401202500S)(00733.167*m3),!9D54,
But really I got confused by these 2 different ways of getting action out of the rules. They now both work but are slightly different. (of course not simultaneously)
Posted: 01 Apr 2024, 21:09
The !Serial* is a bit of legacy as the Serial Server plugin did send it out as a special kind of event which was one of the first kind of events supporting string like arguments.
Later we changed it but left this one in for compatibility reasons as there are setups out in the field using it and you don't want to break working setups.
