Livolo issue
Livolo issue
Hello all,
First, I'm sorry for my english... I'll do my best.
I updated my Rflink to R38 Firwmare to support Livolo switches under my Jeedom server (It's a french automation software).
My rflink has detected messages from my Livolo remote and Jeedom has created a virtual switch acting as the remote, with same IDs. When I use Jeedom virtual to switch the livolo ON or OFF, it is working intermittently, 1 time on 10 tries. Anybody has the same issue ? With jeedom or other software, as Domoticz.
Thank you
Thank you
Re: Livolo issue
I have Livolo also but then with Domoticz and Rflink, I think the Livolo switches are weak on receiving signals.
I have one near the Rflink and that one is working perfect, but another one some walls further doesn't react or only 1 out of 5 times. In the same room there are other Kaku switches which work very well.
Re: Livolo issue
Sorry I am wrong, I forgot that the working Livolo is on my Rfxcom unit. I have both Rfxcom and Rflink on two Raspberry 3 pi's.
So I did a test and moved the Rflink to the perfect working Livolo(under Rfxcom) and indeed it is intermittently, just the same as the not working further away. So only 1 of 5 tries it works or even worser.
Re: Livolo issue
What firmware version?
Re: Livolo issue
Firmware is 41.
Yesterday it worked some better again, I still think the Livolo switches are not that good in receiving signals. But to have it work the position of the antenna is very critical where the Rfxcom almost always works.
There is also a difference in switching, The On and Off signals from Rflink just make the switch go to the other position, so Off can be On and vice versa, it just switches to the opposite position regardless if you send a Off or On signal.
Re: Livolo issue
Is it possible to correct the Livolo On/Off commands?
When I press the On command a second time it switches Off and the same for the Off command, a second Off results in a On command.
Although it seems to be sending a ON command the second ON command results in a Off:
RFLink Sending: 10;Livolo;000c03;8;ON
For the Livolo switch It is just a toggle and not a on or off command.
Thx!
Thx!
Re: Livolo issue
Can you email (frankzirrone@gmail.com) a debug log with your comments?
Re: Livolo issue
I have sent them, thx!
Re: Livolo issue
Have you resolved this issue? I am having the same problem. As far as I have been reading, Livolo supports only Toggle and GroupOFF, but I am unsure how to add the GroupOff switch.Mediacj wrote:I have sent them, thx!
