NTP not working
NTP not working
I try to work with 108 and 115 ver. but still my NTP qere didn't get time from NTP server.
I think all my setings is corect IP: 192.168.20.100/GW"192.168.20.1/SM:255.255.255.0/DNS:212.59.1.1
NTP enabled. But system time is looks like start time...
Also I tried different NTP Hostnames but still nothing...
Wher can be problem....
Thank You.
Thank You.
Re: NTP not working
Works fine here with server 0.rhel.pool.ntp.org
Re: NTP not working
I work with this one: europe.pool.ntp.orglinasg wrote:Hello
Thank You.
Works fine for me.
Re: NTP not working
Some time ago I had NTP issues.linasg wrote:Hello
Thank You.
see http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1683
Maybe this helps you find the problem.
Re: NTP not working
I tried both servers, NTP still does not work .
My settings are as follows (See pictures)
What am I doing wrong?
Thank You
Thank You
- ESP_easy1.png (200 KiB) Viewed 15277 times
- ESP_easy_tools.png (235.84 KiB) Viewed 15277 times
- ESP_easy_config.png (234.05 KiB) Viewed 15277 times
Re: NTP not working
Try to leave the optional settings of ESP empty and fill the SSID and the WPAKey, maybe that is the problem.linasg wrote:I tried both servers, NTP still does not work .
Thank You
And i see that yoy have filled, Timezone Offset: (Minutes) with 1 minute. I believe that's not correct but it works. I checked it by my ESP
Re: NTP not working
In real the SSID and WPA key is to filled, Timezone Offset: I tried set 0; 1; 120 min but still nothing
Re: NTP not working
Your ESP DNS: 212.59.1.1 is that correct?linasg wrote:In real the SSID and WPA key is to filled, Timezone Offset: I tried set 0; 1; 120 min but still nothing
Is't not 192.168.20.1 ?
Try 192.168.20.1 that is for me the only thing whats different with my settings.
Re: NTP not working
I have the impression that your ESP doesn't reach the Internet.
Can you try to setup it using DHCP instead of assign it an ip
Re: NTP not working
Do you have the NTP offset correctly setup? (Found in the advanced page under tools)
Re: NTP not working
Are you german? Then you should have a offset of 60 minutes.
Users browsing this forum: Ahrefs [Bot] and 32 guests
