Well, the FAQ doesn't say much about registering device with an existing physical remote and it states nothing abot "single color leds", but at least I could see that I had most likely to select the "Dimmer" type for the device. And the result is a switch with the RGB colorpanel and below it a slider for brightness.
I had replaced the ID by the one I had noticed in the debug of RFLink when it was connected on PC with RFLInkLOader). Same result and same "RGB" subtype in the Devices list.
- as is, the switch is not very convenient, as I can not use it as a simple dimmer, but need to go into color panel and move the brightness slider
- it seems controlling the milight, but sometimes, behavior is weird: for instance slider was around 80% but actual lighting was very low, and moving the slider up slightly (like to 90%) was indeed increasing light a little bit, but definitely not at almost its max level. I had to switch full ON with remote so that the slider gets consistent again.
- when I activate the remote, Domoticz is not updated: I can see a line appearing in the log (but always the same generic message not very helpful), but the switch (nor the log of the switch) is updated. I tried several buttons of the remote (on and off of the led driver, on and off of the group, the upa nd down buttons of the ring button (which dims up/down the light).. No impact in Domoticz.
As I don't know if it can be done in Domoticz (is there a way to get debug info when connected to Domoticz?), I unplugged and reused RFLink LOader.
I got this (in case it helps, I activated the LogMode debug at some point near the end of the log because I saw that same message was appearing whether I dim up or down with remote ring):
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R44;
20;01;MiLight=ON;
10;version;
20;02;VER=1.1;REV=44;BUILD=08;
10;status;
20;03;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=ON;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
20;04;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
20;05;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ON;
20;06;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=OFF;
20;07;Oregon TempHygro;ID=2D70;TEMP=00cc;HUM=53;HSTATUS=1;BAT=OK;
20;08;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ON;
20;09;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ALLON;
20;0A;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=OFF;
20;0B;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;0C;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;0D;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;0E;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
20;0F;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ON;
20;10;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;11;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;12;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;13;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;14;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;15;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;16;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;17;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=BRIGHT;
20;18;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;19;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;1A;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;1B;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;1C;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;1D;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ON;
20;1E;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=OFF;
20;1F;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=COLOR;
20;20;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;21;MiLightv1;ID=5A3878;SWITCH=01;RGB=FF00;CMD=COLOR;
20;22;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;23;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;24;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=OFF;
20;25;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ON;
20;26;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=OFF;
20;27;MiLightv1;ID=5A3878;SWITCH=01;RGB=0000;CMD=ON;
20;28;Oregon TempHygro;ID=2D70;TEMP=00cc;HUM=53;HSTATUS=1;BAT=OK;
20;29;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;2A;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;2B;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;2C;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=BRIGHT;
20;2D;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;2E;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;2F;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;30;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;31;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;32;MiLightv1;ID=5A3878;SWITCH=01;RGB=00FF;CMD=ALLBRIGHT;
20;33;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;34;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
20;35;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;36;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;37;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ON;
20;38;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ALLON;
20;39;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ALLON;
20;3A;Oregon TempHygro;ID=2D70;TEMP=00cc;HUM=53;HSTATUS=1;BAT=OK;
20;3B;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ALLON;
20;3C;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;3D;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;3E;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;3F;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;40;MiLightv1;ID=5A3878;SWITCH=00;RGB=FF00;CMD=COLOR;
20;41;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;42;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=ALLBRIGHT;
20;43;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ON;
20;44;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
20;45;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;46;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=ON;
20;47;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;48;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;49;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4A;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4B;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4C;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4D;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4E;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;4F;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;50;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;51;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;52;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;53;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;54;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;55;Oregon TempHygro;ID=2D70;TEMP=00cc;HUM=53;HSTATUS=1;BAT=OK;
20;56;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
10;rfdebug=on;
20;57;RFDEBUG=ON;
20;58;MiLight DEBUG;Bytes=07;5a3878000c4764;
20;59;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;5A;MiLight DEBUG;Bytes=07;5a3878000c4865;
20;5B;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;5C;MiLight DEBUG;Bytes=07;5a3878000c4966;
20;5D;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;5E;DEBUG;Pulses=34;Pulses(uSec)=1740,1110,30,540,210,30,360,270,180,2580,120,1320,150,180,330,60,3450,30,90,60,990,120,510,90,1560,30,180,30,150,0,1350,330,420,120;
20;5F;MiLight DEBUG;Bytes=07;5a3878000c4a67;
20;60;MiLightv1;ID=5A3878;SWITCH=00;RGB=00FF;CMD=BRIGHT;
20;61;MiLight DEBUG;Bytes=07;5a387800044b60;
20;62;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;63;MiLight DEBUG;Bytes=07;5a387800044c61;
20;64;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;65;DEBUG;Pulses=23;Pulses(uSec)=3000,180,1170,300,210,330,180,90,150,3960,30,240,1530,0,180,90,570,30,420,930,90,990,30;
20;66;MiLight DEBUG;Bytes=07;5a387800044d62;
20;67;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;68;DEBUG;Pulses=29;Pulses(uSec)=60,0,1440,930,210,60,30,900,1560,120,30,60,30,480,180,690,30,300,90,240,1980,240,30,210,60,150,210,150,180;
20;69;DEBUG;Pulses=30;Pulses(uSec)=30,570,90,210,1500,60,180,60,360,90,660,240,60,1200,540,90,1320,300,360,150,1470,960,30,1350,390,1200,30,90,900,30;
20;6A;MiLight DEBUG;Bytes=07;5a387800044e63;
20;6B;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;6C;MiLight DEBUG;Bytes=07;5a387800044f64;
20;6D;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;6E;DEBUG;Pulses=24;Pulses(uSec)=1620,90,120,240,1050,30,240,120,270,180,210,300,30,210,60,2340,510,60,3960,4380,750,2250,2040,390;
20;6F;MiLight DEBUG;Bytes=07;5a387800045065;
20;70;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;71;MiLight DEBUG;Bytes=07;5a387800045166;
20;72;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;73;MiLight DEBUG;Bytes=07;5a387800045267;
20;74;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;75;DEBUG;Pulses=23;Pulses(uSec)=840,30,30,330,510,150,1470,1140,90,3600,270,90,480,120,240,720,1830,180,150,840,60,480,2250;
20;76;MiLight DEBUG;Bytes=07;5a387800045368;
20;77;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;78;MiLight DEBUG;Bytes=07;5a387800045469;
20;79;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;7A;DEBUG;Pulses=31;Pulses(uSec)=120,870,30,360,1920,30,150,630,180,60,2220,510,90,150,540,990,60,1050,30,240,30,120,330,840,270,720,1740,390,30,1080,120;
20;7B;MiLight DEBUG;Bytes=07;5a38780004556a;
20;7C;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;7D;DEBUG;Pulses=29;Pulses(uSec)=90,30,240,30,1500,30,720,30,300,30,660,210,240,150,930,30,510,120,90,1530,60,450,180,300,90,1140,960,90,30;
20;7E;MiLight DEBUG;Bytes=07;5a38780004566b;
20;7F;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;80;MiLight DEBUG;Bytes=07;5a38780004576c;
20;81;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=BRIGHT;
20;82;MiLight DEBUG;Bytes=07;5a387800095872;
20;83;MiLightv1;ID=5A3878;SWITCH=00;RGB=0000;CMD=OFF;
20;84;DEBUG;Pulses=230;Pulses(uSec)=720,1920,330,1020,750,960,810,930,840,900,840,900,840,900,840,900,840,900,870,900,870,900,870,870,870,870,870,870,870,900,870,420,360,900,390,390,870,390,360,900,360,390,870,900,870,390,360,900,840,900,870,870,360,420,870,390,360,900,390,390,840,900,840,420,360,900,390,390,870,390,390,900,870,870,870,900,840,900,870,900,840,870,870,900,390,390,840,420,360,870,870,900,840,900,840,870,870,900,870,870,390,420,870,870,870,870,870,420,360,870,870,900,870,900,870,870,870,870,870,900,840,900,390,390,840,420,360,870,870,870,870,900,840,900,870,870,870,900,360,420,870,390,390,900,840,900,870,870,870,900,870,870,870,900,360,390,840,900,870,420,360,870,870,870,390,390,840,420,360,900,360,420,840,420,360,900,870,900,870,870,390,420,840,390,360,900,360,390,870,900,840,420,360,870,390,390,840,420,360,870,390,390,870,390,360,900,840,870,870,900,360,420,840,390,360,900,390,420,840,870,870,870,870,390,360,900,390,390,840,6990;
20;85;Oregon TempHygro;ID=2D70;TEMP=00cc;HUM=53;HSTATUS=1;BAT=OK;
20;86;DEBUG;Pulses=23;Pulses(uSec)=900,90,30,150,0,0,690,120,420,360,180,840,30,150,30,630,210,1080,210,30,450,240,270;
10;rfdebug=off;
20;87;RFDEBUG=OFF;
20;88;Oregon TempHygro;ID=2DD5;TEMP=0088;HUM=69;HSTATUS=0;BAT=OK;
In above log, I used nearly every button of the remote: the ones linked to led driver, the ones for the group, and the ones from the ring (which dim up/down the light).
I'd appreciate your help to understand what I do wrong, but if I can help by providing some tests or whatever, I'm also happy to do so.
