Did you have success with this board? I am keen to order a couple for my halogen downlighters.DeNB3rt wrote:okay thanks! my MPDMV4 arrived today
AC Dimmer for ESPeasy
Re: AC Dimmer for ESPeasy
Hi David,davidlightsa wrote:Did you have success with this board? I am keen to order a couple for my halogen downlighters.DeNB3rt wrote:okay thanks! my MPDMV4 arrived today
You can find more MPDMv4 related informations on this dedicated thread:
viewtopic.php?f=2&t=2362
Happy breadboarding,
TJ.
www.esp8266-projects.com - ESP8266 Projects and many more!
MPDMv4 Universal AC Dimmer is available also on TINDIE Store: https://www.tindie.com/stores/nEXT_EVO1/
yes, very happy with it.davidlightsa wrote:Did you have success with this board? I am keen to order a couple for my halogen downlighters.DeNB3rt wrote:okay thanks! my MPDMV4 arrived today
Check the thread in projects.
mgennip,
Can this code code be used for 2 channel AC dimmer.If so what do I have to add to your original code?
Did you make a plugin for ArduinoEasy?mgennip wrote: ↑17 Nov 2016, 13:03 I have made an ESP8266 AC dimmer with an Atmega328 for phase control. Next week I will post the schematic and code on my website http://www.van-gennip.com
An ESP8266 runs on ESPEasy firmware and i have made a plugin that talks I2C to the Atmega328. It is similar to the pro mini extender, but my Atmega does the zero crossing detection and phase shifting.
It is in an earlyworking stage, but when i share my thoughts, i am sure that this will be picked up by others.
I’m currently in testing my own ac dimmer, and trying to fit it all in a european in wall box.
Curently i’m using a esp-12 for rhe communication, for controlling the light i use a attiny85.
I wrote my own plugin as far as i can see it is working fine, try to adjust a few more things and then going to develope a new pcb, the last one had some mistakes in it.
Great! Will you be sharing more tech details and/or schematic?arnoldg wrote: ↑31 Dec 2017, 16:03 I’m currently in testing my own ac dimmer, and trying to fit it all in a european in wall box.
look at the dutch page https://www.circuitsonline.net/forum/view/139309/1
but this was version 1, after getting the print i discoverd some problems, the E-12 needs more connections then i thought.
I let go i2c and now communicating with serial. becaus i need the int0 pin on the tiny for zcd.
now i'm in the process of remoddeling the stuf to get a new, better working dimmer board.
but first i wan't it all to control it over mqtt, here i'm a little stuck still in the processes of fiddeling out code and that kind of stuff
Just uploaded a video with regards to the development of Meek MD1 ( Meek Wi-Fi enabled Dimmer)
https://www.youtube.com/watch?v=Y9hVDwKcEDw
Do you have code sample for pro mini ?
Yes, I do, but it’s very “dirty” and still "work in progress".
Once I have implemented all the options, I will clean the code and put some explanations in the code for the ease of use/distribution.
I have placed the dirty code of the Meek MD1 dimmer, on the following topic :
viewtopic.php?f=2&t=3721
I’ve just received the PCB’s for the Meek MD (Wifi Dimmer).
Unfortunately, the ATmega328 has not been delivered yet.
Once I have them in my possession, I will assemble and post some info.
In the meantime I will work on the dimmer codebase.
Attached you’ll find a picture of the dimmer PCB’s.
Users browsing this forum: Google [Bot] and 14 guests
