RFLink and Somfy RTS curtains & sockets
cybermaus
#1 Post by cybermaus » 24 Nov 2016, 18:32
RTlink R44 + Aurel Transceiver RTX-MID-5V 433MHz
Domotics 3.5877
Somfy Glydea curtain
Somfy wall socket switches (3x) E200 RTS F-TYPE
By example of this French page, using the RTlink on its console, I can fully control my Curtains and wall sockets. I seem to have no trouble with the slight frequency difference (433,42 vs 433,92) of the Somfy's, all commands from the RTLink to the devices are executed reliably. (receive from Telis 4 RTS remote is less reliable, but that worries me less)
When connecting the RTLink to the Domoticz it breaks down. The log hints that the issue is that the Domoticz sends " ON/OFF" rather then "UP/DOWN".
HOWEVER, looking more closely, I now suddenly notice that RTLink supports both command sets, but uses the ON/OFF the wrong way around !!
Going back to the console for the RTLink I find that these commands work for my sockets:
Tested to both ID=0f040f (socket), and ID=0f010f (curtains)
10;RTS;0f040f;1;UP   # Socket comes on      # Curtain opens
10;RTS;0f040f;1;DOWN # Socket goes off      # Curtain closes
10;RTS;0f040f;1;STOP # Socket does nothing  # Curtain continues
10;RTS;0f040f;1;ON   # Socket *goes OFF* !  # Curtain closes
10;RTS;0f040f;1;OFF  # Socket *comes ON* !  # Curtain opens
So I guess this may have slipped by because the directions of UP/DOWN as well as ON/OFF are unclear anyway. At least when talking about curtains (more like open-close) or blinds (more like backward-close via middle-open to forward-close ?) For shutters and rollers UP/DOWN may be clear. But those systems have a 'reverse' motor setting, maybe people fixed it with that.
Anyway, on wall-wart sockets, ON and OFF are quite well defined, no ambiguity whatsoever, and currently clearly wrong. And also unlike all the Somfy motors the socket does not have a programming setting to 'reverse', so I cannot even fix it.
Not quite sure if this is a bug and if it can or should be fixed in the TRLink firmware, Maybe already too many people using it with the current meaning?
Anyway: specific questions to this forum:
- Is my thinking above correct, and is this a bug?
- If so, is the bug locked in (now a feature) or should it be fixed?
- If not so, what am I doing wrong?
- How many people are using Somfy RTS with RTLink (I believe its a fairly young addition, and I only found half a dozen threads)
And most importantly (the core question in fact):
- How to get Domonicz to start using OFF/ON rather then ON/OFF?
Maurits
PS: the STOP does not seem to work at all.
Stuntteam
Site Beheer
Re: RFLink and Somfy RTS curtains & sockets
#2 Post by Stuntteam » 25 Nov 2016, 00:58
I think it is best to contact me directly via frankzirrone@gmail.com
that way we can sort things out and get you some test versions.
