[Solved] Add a new device: RFLink: TX time out... in domoticz
Posted: 12 Dec 2016, 17:50
Hi everyone.
I try to do a search with these terms without success (becase i can't search time, out, domoticz, too general terms)
I have domoticz in a Rpi.
I use minicom to check the receive signal and i have the following when i press a button of my remote:
When i try to perform a command in the domoticz hardware for example
It tells me
Do i make something wrong or there is another issue?
On the other hand if i wait the domoticz recognition, and if u do a on/off action i have:
So the first time i use the swith, it is ok and all the others are KO
20;EB;NewKaku;ID=03d1f400;SWITCH=2;CMD=ON;
11;EB;NewKaku;ID=03d1f400;SWITCH=2;CMD=ON;
2016-12-12 17:49:21.555 User: initiated a RFLink Device Create command: 11;44;NewKaku;ID=03d1f400;SWITCH=2;CMD=ON;
2016-12-12 17:49:26.000 Error: RFLink: TX time out...
2016-12-12 17:52:00.434 User: Admin initiated a switch command (81/Radiator/Off)
2016-12-12 17:52:00.435 RFLink Sending: 10;NewKaku;3d1f400;2;OFF
2016-12-12 17:54:13.613 User: Admin initiated a switch command (81/Radiator/On)
2016-12-12 17:54:13.622 RFLink Sending: 10;NewKaku;3d1f400;2;ON
2016-12-12 17:54:18.000 Error: RFLink: TX time out...
