Congratulations for this fantastic RFLink project.
I've just bought the nodo kit for RFLink 433. I use it with Domoticz to catch data from OWL usb meter. I have the last stable version for RFLink and Domoticz. The kit works well and retrieve some information from OWL. But in Domoticz, by default the device OWL isn't reconized as it is. It was 'Oregon CM119' . I've take a look on data sent by RFLink with RFLink Loader debugger. You will find here debug data :
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
20;03;Oregon CM119;ID=009A;WATT=05d8;KWATT=0000b88a;
10;rfdebug=on;
20;04;RFDEBUG=ON;
20;05;DEBUG;Pulses=212;Pulses(uSec)=480,330,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,450,360,420,360,420,360,420,360,420,360,420,360,450,330,420,360,450,360,420,360,420,360,420,360,420,360,420,360,420,840,930,840,930,840,930,840,420,360,930,840,420,360,420,360,420,360,420,360,420,360,930,840,930,840,930,360,420,840,450,330,930,840,930,840,420,360,420,360,420,360,420,360,930,360,450,840,930,840,420,360,450,360,420,360,420,330,420,360,420,360,420,360,450,330,930,840,420,360,930,840,930,840,930,840,930,360,420,360,420,840,420,360,930,840,930,840,450,330,450,330,420,360,930,840,930,840,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,450,360,420,360,420,360,420,330,450,330,450,330,450,330,420,360,450,330,450,360,420,360,930,360,420,840,930,360,420,840,930,840,930,840,420,360,930,840,420,360,420,360,930,6990;
20;06;Oregon CM119;ID=009A;WATT=0588;KWATT=0000b8a0;
20;07;DEBUG;Pulses=214;Pulses(uSec)=540,330,450,330,450,330,450,330,420,360,450,330,420,360,420,360,420,360,420,360,420,360,450,360,420,360,420,360,420,360,420,360,420,360,420,360,450,360,450,330,450,360,420,360,450,360,420,840,930,840,930,840,930,840,420,330,450,360,450,330,420,360,420,330,450,330,450,330,450,330,930,840,930,840,930,360,450,840,420,360,930,840,930,840,420,360,420,360,450,330,420,360,930,360,420,840,930,840,450,330,420,360,450,330,420,360,420,360,420,360,420,360,420,360,420,360,420,360,930,360,450,840,420,360,930,360,420,840,930,840,420,360,930,840,930,840,930,840,420,360,420,360,420,360,930,840,930,840,420,360,420,360,420,360,420,360,420,360,450,330,450,330,420,360,450,330,450,330,450,330,420,360,420,360,450,330,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,930,840,930,840,930,840,930,840,930,840,930,360,420,840,930,6990;
20;08;Oregon CM119;ID=009A;WATT=0588;KWATT=0000b8a5;
Is anyone could explain me why RFLink didn't detect the right device (OWL Usb) or is it just the same data pattern for both devices ?
Thanks for your feedback.
RFLink and OWL Usb
Re: RFLink and OWL Usb
OWL USB sends data with the same format as the OWL CM119...So there was no need for additional names/detection.
You should be able to use it in Domoticz.
Thanks for your reply. No problem, it works very well with Domoticz. You confirm that OWL Usb is same device than OWL CM119.
Bye.
Bye.
