Domoticz Milight Touch Remote using RFLink
Posted: 26 Feb 2017, 14:19
Milight touch remote (the one with the four zones at the bottom and a colour wheel change) is recognised by Domoticz using RF Link Gateway. However, the dim and colour values aren't. In RFLink debug I can see the signal is being received okay with the four digit Milight RGBW value (two digits for colour and two for dim), but in Domoticz, the svalue doesn't correspond to this value at all. When I look at Svalues for a particular Milight zone and change the dim level using the remote, it is all over the place, as though Domoticz is not translating the four digits to colour and dim level.
To get these working would be great, since they are so cheap and I want to use them as cheap wall dimmers for each room. I have lots of Hue bulbs and Milights, so to have a simple hardware control would make life easier (using apps is a pain). However, unless I can actually read the correct dim levels then I am stuck.
Any ideas?
Any ideas?
