OpenHAB MQTT broker connection failing all the time
Posted: 17 Apr 2017, 12:39
Hi all,
I finally was able to spend some time learning Atom/PlatformIO and I quite like the new setup!
This enabled me to jump back onto ESPEasy after a few months of inactivity, and was able to compile and upload a 4M binary on a Wemos D1 Mini I have.
Everything worked at the first test, and I was able to configure my first ESPEast v2.0 build partly via the serial port and partly via the web interface.
I have a Mosquitto instance working well connected to both two Espurna instances (one on a NodeMCU and another on a Sonoff) and a Node-RED instance, all working well with Mosquitto, pulling and pushing messages from the MQTT broker.
Turns out the new ESPEasy instance cannot connect to same broker.
What I get in the serial console debug is:
What I get in the /var/log/mosquitto/mosquitto.log file is:
and I am getting quite a lot of these.
This happens no matter what choice of MQTT controller I choose, be it Domoticz, OpenHAB or PiDome. Same errors.
Is there anything I am missing? Is there any way to provide more debugging?
Many thanks,
Luca
MQTT : Connection lost
MQTT : Failed to connected to broker
1492425123: New connection from 192.168.1.104 on port 1883.
1492425123: Socket error on client <unknown>, disconnecting.
Many thanks,
Luca
