Connecting a TM1637 4-Digit Display
Re: Connecting a TM1637 4-Digit Display
#201 Post by grovkillen » 02 Dec 2018, 20:51
Alternating between clock and outdoor temperature is one example or clock plus room CO2 level, another example.
oisisi
#202 Post by oisisi » 02 Dec 2018, 20:59
To be able to change modes remotely per command generally makes sense, imho. What would happen if you just remove the break from the command functions?
papperone
#203 Post by papperone » 03 Dec 2018, 20:42
oisisi wrote:
02 Dec 2018, 20:59
Not sure it's a good practice, I will implement new command to change module mode so user can use it in rules with timers...
grovkillen wrote:
02 Dec 2018, 20:51
Ok you are right, you gave me some idea how to improve one of my module :)
Let me find few minutes later this week and I will implement mode-change command indeed!
PS: I'm just not sure what will happen when I will make multiple display works, as they are now commands are not able to point a specific device and they will be exectuted only by the first occurrence of any given plugin :(
#204 Post by grovkillen » 03 Dec 2018, 21:19
Yes we need to be able to point which display/task number the command is addressing. But that is core development on a more generic level.
venom
#205 Post by venom » 04 Dec 2018, 14:51
hey, could anyone confirm if this one is supported:
I've bought it here: https://www.aliexpress.com/item/1PCS-4- ... 4c4duUAft7 but seems I've got a newer one as the label on it says "V1.1" rather than "V1.0".
I think I've tried all possible settings combinations and all supported commands from wiki but no luck - I can't get it to work - it looks turned off all the time.
The device itself is fine - I managed to run it following that: http://www.esp8266learning.com/tm1637-7 ... xample.php.
Could anyone advise?
papperone
#206 Post by papperone » 04 Dec 2018, 22:19
Have you tried to swap CLK and DIO pin setting on the device config (not touching the physical wiring)?
venom
#207 Post by venom » 05 Dec 2018, 22:30
Yes, I have. Tried to change the settings, rebooted D1, played with display output (manual, date, etc), run some commands (cmd=7don, cmd=7db,15, etc) - still no reaction from the display :/
papperone
#208 Post by papperone » 06 Dec 2018, 06:58
that's vcery weird as all my displays of different brands and configuration works perfectly...
as well the code in the plugin is writte following the spec of the datasheet of the supported IC, which I guess it's the same with the library you pointed and it's first time I've got reported such behaviour (plugin does not work while the library does)...
I coudl look into library but honestly I've lack of free time due to my job so not sure when I will be able to do it and on top of it I've not hardware to test so it will make this debugging very tricky!
venom
#209 Post by venom » 07 Dec 2018, 07:17
OK, sure. Thanks anyway.
Black_Knight
#210 Post by Black_Knight » 20 Jan 2019, 21:14
I think i'm in the same boat. I can't get my 7segs to display. I've 3 setup from a while back which are working fine, but I've ordered new ones and none of them are displaying. I've verified they work using the same script as you mentioned:
kimot
#211 Post by kimot » 22 Jan 2019, 09:09
@venom
It is simple problem.
On picture I can see you power your TM1637 from 5V on Wemos.
If you look at the TM1637 datasheet, you can read:
Min. Log H = 0.7Vdd
0,7 * 5 = 3,5V
But your ESP runs on 3,3V, so never reach 3,5v on gpio output.
Try power TM1637 from 3,3V pin
Patou
#212 Post by Patou » 13 Feb 2019, 14:34
Already a lot of post for the 7 segment display ... means a lot of people wants to use it !!
It looks like the plugin is not yet totally debugged.
My situation :
Esp 8266 lolin running very good other application
firmware : ESP_Easy_mega-20180513_dev_ESP8266_4096.bin ( i tried newer firmware but the problem looks the same)
Display 8 digit Max 7219
On 10 to 20 starts ( reboot with button / reboot from PC or power supply on/off ) only one time the display indicated the clock or the date
On the other tentatives : the display stays blank or just the last digit is running from 0 to 9
When the display is running correctly performing a reboot or power on/off make a blank screen
I have checked the power supply : 3.28VDC stable ( only ESP 8266 running at that time on the power supply
Do somebody else have the same situation ?
Users browsing this forum: Google [Bot] and 1 guest
