Connecting a TM1637 4-Digit Display
Re: Connecting a TM1637 4-Digit Display
Hello.
I want to thank the developer for his work!
I wanted to find out if there was some way to switch the plugin's operating mode ("clock" or "manually") by commands from the rules or by a http request, rather than on the device page in ESPEasy?
If not, is it possible to implement?
@Papperone,
thanks for this plug-in.
Is it possible to combine this plug-in with a PCF8574 I/O expander ?
A quick test of the mega release ESPEasy_mega-20180119 showed only the regular GPIO's and not the PCFGPIO's from PCF8574.
Thanks for your response.
Domosapiens
Domosapiens
Hi, I am waiting some new displays models in order to implent them in the next release of this plugin.Domosapiens wrote: ↑19 Jan 2018, 23:59 @Papperone,
Domosapiens
I think I shoudl have somewhere such expander PCF8574; if I will find it I will have a look if it can be easily implemented your request
I can send you 1 or 3 if you don't have some at home.
@Papperone,
hope you can do it.
It would be a major break-trough: using PCFGPIO's as generic GPIO's.
(f.i. also for HC-SR04 distance measurement, IR Transmit etc.)
Thanks in advance !
hope you can do it.
Thanks in advance !
Same, have several PCF8574 DIP-housing in the shelf.
Let me know.
Don't worry I've just found PCF8574 so I can start experimenting with that!
I already opened a generic Issue/Enhancement request on github as I do believe we shoudl add expanders in the ESPEasy core code, this will allow *any* plugin to access both internal or external GPIOs seamlessly https://github.com/letscontrolit/ESPEasy/issues/749
BTW: There are many expanders similar to PCF8574, even with 16 GPIOs (MCP23017) so will be tricky to implement them all, so let's park it here and think about it...
hello, I have seen this plugin, thanks a lot for his developpement. I am interested in, found the source and would like to implement on an ESP-01.
However I don't succeed to compile, many errors found ( using ESPeasy R120 due to memory limitations).
Is it possible to have it working on this ESPeasy release ???
regards
regards
hello,
Nobody to respond ?
I precise the compilation error is with the function AddFormNote in PLUGIN_WEBFORM_LOAD.
_P073_7DGT:90: error: 'addFormNote' was not declared in this scope
addFormNote(string, F("TM1637: 1st=CLK-Pin, 2nd=DIO-Pin"));
I am using Arduino 1.8.5 and ESPcore 2.30
regards
Nobody to respond ?
regards
I would suggest switching over to one of the newer branches (v2.0 or Mega), since all active development is done there.
What are the memory restrictions you have?
ESP-01 has only 512k memory, so we cannot install v2.00 or mega version
Hi papperone,
I have posted a problem I have with SendToHTTP in this thread. I am informing you as well, in case it relates to your build.
Nope.
The old version (Usually on a blue PCB) has 512K
Newer versions (Black PCB) have 1MB and can be used with the 1024-Binaries of ESPEasy 2.0.0/Mega.
Please beware:
At this time there are some ESP-01 with a PUYA flash chip.
These flash chips do not work with ESPEasy atm, they have a problem with SPIFFS memory.
This problem is under investigation, but that will take a while.
There is solution, but we still have to implement it.
Nice! Good job.
But still no solution that is ready to use
I received finally the new 7digit modules with M1637 and new config (6 digits and with decimal dots).
I will try to find some spare time to update the plugin to have support for them, about the SendtoHTTP bug I don't this can be connected but I'll have a look.
Great news Papper! Just a reminder, I got them displays myself in case you need me to test something
Either I'm not lucky at all (and I got 4 DOA brand new displays from Robodin) or something is weird here...
None of the brand new 4 displays I've got, despite I bought branded ones, seems to work
@Grovkillen: can you connect one of the new type of displays you got as well and see if they react with old plugin? they are pin to pin compatible so at least the digits shoudl be shown...
Will try it tomorrow.papperone wrote: ↑13 Feb 2018, 18:38 Either I'm not lucky at all (and I got 4 DOA brand new displays from Robodin) or something is weird here...
Meanwhile I've found last night a differen library for Arduino (not working on ESP8266) which can drive both old and new type of displays...
That's weird as they both uses TM1637 and I build the plugin from scratch using the info taken from the IC datasheet, but... obviously I overlook something or the new display have something different which I cannot still spot.
Anyhow I think it will take longer than expected as I will need to reverse engineer the new lib I've found to understand how it is driving the IC and to implement the same changes in my plugin (which does not uses any library).
I do apologize for the delay
As you probably already knew, I cannot get mine to shine neither.papperone wrote: ↑14 Feb 2018, 10:40 Meanwhile I've found last night a differen library for Arduino (not working on ESP8266) which can drive both old and new type of displays...
Hallo,papperone wrote: ↑14 Oct 2017, 00:31it's in my "to-do" list but probably as a separate plugin as this matrix led can be more flexible and customizablegrovkillen wrote: ↑13 Oct 2017, 23:52 Will dot matrix displays powered by MAX7216 be supported? Just curious.
is this still on your to-do list?
I think it‘s a good idea. The Dot Matrix looks very good.
With best regards Holgi
Yes it is! Right now I need to rework the TM1637 interface to enable compatibility with newer modules, then I'll work on implementing dot matrix displays!The-Holgi wrote: ↑14 Feb 2018, 21:54Hallo,papperone wrote: ↑14 Oct 2017, 00:31it's in my "to-do" list but probably as a separate plugin as this matrix led can be more flexible and customizablegrovkillen wrote: ↑13 Oct 2017, 23:52 Will dot matrix displays powered by MAX7216 be supported? Just curious.
hello,
on my side I have made supplemental tests. I have 2 displays available
First test: connect on arduino Uno with a small prog to display random data --> OK on the 2 displays
2nd test : connect on Wemos with espeasy v2 : No. don't work- no display
3d test : connect on ESP12E with espeasy V2: NO- don't work- no display
espeasy works fine on wemos and esp12 with gpio tests ( leds connected)
As there is a level potential issue on the displays (5V on arduino, 3V3 on ESP) I have ordered level shifters to check.
regards
regards
Yes I have all new modules that does not work with my plugin while the modules I've boughy few months ago works perfectly.38domo wrote: ↑17 Feb 2018, 16:19 hello,
regards
Nevrtheless on a bare ESP8266 with the original library I've the same behaviour while using a different library I'm able to drive both old and new type displays.
Something must have changed in the TM1637 IC as there's no other explanation nor components on the module to explain such behaviour; I'm currently working to understadn the difference between old and new library to fix the plugin...
I just wanted to add that I bought several of these units and unfortunately they also don't work with this plugin. There is no output visible. They work from Arduino or from Raspberry Pi. Weird, right?
https://nl.aliexpress.com/item/4-Digit- ... 69551.html
I have made a PR here:
https://github.com/letscontrolit/ESPEasy/pull/996
This PR fixes the No Display (+ also hangs, crash, etc...) issue for a recent (RobotDyn in my case) 4seg display, using a NodeMcu v2.
You can test it by compiling my branch fixTM1637
Please reports IN THE PULL REQUEST ONLY :
- does it STILL work on older displays (that used to work with the previous code) or not?
- is it stable (no over Load usage, or hangs) or not?
- is it working with your recent displays?
if it doesnt work on your diplay , you can experiment with a bigger TM1637_BIT_DELAY, ie 100, and report
If it is reported to work on both old and new displays, maintainers will certainly merge it fast.
Soif
Want to update ALL your ESP babies OverTheAir, or backup their settings in ONE simple command, + many other cool features.... Adopt EspBuddy
Thanks for the proposed fix. Would it be alright to trouble you for the compiled firmware; i.e. would you be willing to post that somewhere? Preferably for a 4M-version ESP8266?
It is already merged and there should be a new build tomorrow morning.victorclaessen wrote: ↑03 Mar 2018, 21:43 Thanks for the proposed fix. Would it be alright to trouble you for the compiled firmware; i.e. would you be willing to post that somewhere? Preferably for a 4M-version ESP8266?
Ah, right. I can confirm that my TM1637 units (the ones obtained here: https://nl.aliexpress.com/item/4-Digit- ... 69551.html) work. Thanks for fixing this!
By the way, when I send "7dn,8.5", the display reads "8", where I would expect it to read "8.5". And when I send "7dt,8.5" it reads "8:5°", where I would expect "8.5°". Is my expectation wrong, or could this be an issue related to this specific module? Any thoughts?
Thanks for the quick PR but I had already fixed the timing issue; I am still working to handle better this new display which has both "dots" and "colon" (that's causing the strange behaviour of last post from victorclaessen).
As soon as it's completed (including the handling of the 6-digits TM1637) I'll make the PR in order to have it tested...
thanks for your GREAT work ! I'm sure that you will clear this better for all of us ASAP ! cheers
BTW my display has NO colon, but just dots (x4)
Soif
yes, I know, so far i've got 4 different displays (I've received all of them so I can test all before to release next version).
1) 4 digits and only colon
2) 4 digits and only dots
3) 4 digits with both colon and dots
4) 6 digits with dots
BTW can someone owning one of the "OLD" displays can CONFIRM
that it still works with my latest (merged) PR ?
Soif
if you only changed the timing I can confirm it works, as I own as well some old displays and even increasing the delay they keep working...
Unfortunately after some struggling and reverse engineer of module (3) I've found out that despite the display has both "colon" in the middle and "dots" after each digit the "dots" are not connected to the TM1647...
Long story short, module (1) and (3) behave exactly the same, so I removed module (3) from the drop down, already implemented module (2) and tested.
As it's late and I've lost my focus on coding I'll finish implementing module (4) tomorrow then will make the PR (after verifying that MAX7219 still works and I've not broken anything!)
I tried to commit the new version of the pluing into the 2.0 branch but for some reasons GitHub desktop still keep adding it to the HLW8012 PR which is pending since month waiting for a solution.
Despite in GitHub I created a new PR when I try to merge it GitHUB (on the web) keeps adding anythign to the previously opened one.
If someone can explain how I can make GitHUB desktop understand I really want a new commit separated from the pending one(s) it woudl be very apreciated!!!
I split both PRs.papperone wrote: ↑10 Mar 2018, 14:40 I tried to commit the new version of the pluing into the 2.0 branch but for some reasons GitHub desktop still keep adding it to the HLW8012 PR which is pending since month waiting for a solution.
Can you have a look at this one to check I took the correct version?
https://github.com/letscontrolit/ESPEasy/pull/1043
Then I will merge it.
Thanks TD-er, really apreciated the help and sorry for the mess!TD-er wrote: ↑10 Mar 2018, 18:41 I split both PRs.
@everyone: new P073 is on GitHub, supporting below modules; please test all modules you have and report to me eventually any bugs found.
MAX7219 8digit
TM1637 4digit (colon)
TM1637 4digit (dots)
TM1637 6digit
**NOTE** if your TM1637 4-digit module has both colon and dots most probably only colon is connected thus it will work same as the one described as "TM1637 4digit (colon)"
Please forgive me the bad code but those modules are really weird, most of them the digit addresses are in the right subsequencial order (e.g. 1234 or 12345678) but the ones 6-digits I've got have all swapped order "321654"
hello, I have tested this week end : wemos D1 with display 4 digit with colon & dots.
It's works fine . thanks a lot for the development.
I can manage the brigthness using the web interface but how can we manage the brightness by command (http/mqtt or Rules)?
gerard
gerard
Wiki si your friend --> https://www.letscontrolit.com/wiki/inde ... nt_display38domo wrote: ↑12 Mar 2018, 19:18 hello, I have tested this week end : wemos D1 with display 4 digit with colon & dots.
gerard
hello,
Thanks a lot.
I have tested from http:
http://ip_esp/control?cmd=7don
http://ip_esp/control?cmd=7doff
http://ip_esp/control?cmd=7db,x
works fine.
I will try with mqtt this evening
Thanks a lot.
works fine.
hello,
to use with mqtt:
send to your mqtt broker
msg.topic = "sysname/cmd"
msg.payload = "7db,15"
it works fine
to use with mqtt:
it works fine
thanks a lot 38domo, can you please post a picture of your display to confim which one you tested?
Or maybe refer to the pictures I've postes fwe message before...
hello,
it is the display with dots & semi colon
- IMG_20180316_183052-ConvertImage.jpg (185.02 KiB) Viewed 465793 times
Is it possible to use multiple LED displays at once ESP ?
only one works (
only one works (
- 2018-05-22_1806.png (26.27 KiB) Viewed 465434 times
- 2018-05-22 18.00.30.jpg (2.71 MiB) Viewed 465434 times
Hi, Papperone,
I'd like to create a bit more flexibility in what the plugin can display on the 7-segment modules, to allow for some alpha characters (I want to be able to indicate an error condition and loss of wifi, that sort of thing... Err, dISc, Off, ...)
I was thinking of copying the plugin and making the changes in the playground, but then I found this thread and I see that you've had to do some "interesting" stuff to make the code work with the different versions of the TM1637, so I thought maybe it would be better to suggest the changes to you and see if you have the time to make them, rather than for me to break something!
What I'm thinking, is:
- 7db,n,n,n,n for binary data - each 'n' would be a decimal value 0-255 representing the binary bits sent for that digit of the display; this allows us to switch on any combination of segments;
- 7ds,"ABCD" for string data (e.g. hexadecimal or text)... the characters AbcdeFhIJLoPStuy should all be possible to create with 7 segments.
What do you think, is that something you could do, or is it better if I learn how to modify the plugin and try my skills?
Jeff
Jeff
Various D1 & Sonoffs with ESPEasy, some Tasmota. Domoticz, Z-wave.
ESPEasy Patreon - keep up the good stuff, guys!
1) yes currently only one display is allowed, still need to spend some time to implement multiple displays...
2) definitely yes, it was somethign planned to add alphabetical chars but still not done; I'll fin dsome free time to implement this new features and will take your suggestion but I'm puzzled what is the application for the "binary" feature you asked, can you please elaborate more?
I should have asked before I bought 4 pcs ( Thank you for your info. Good luck with upgrading
Users browsing this forum: Google [Bot] and 32 guests
