RFLink R47 available
Posted: 15 Sep 2017, 17:42
The new RFLink firmware has been released!!
R47: (15/09/2017)
- New Device: Micro Tybox X2D / Tybox H X2D Thermostats (works with 433 and/or 868 mhz)
- New Device: Tybox 310 X2D Thermostat (868mhz)
- New Device: Delta Dore - Deltia 8.03 X2D Thermostat (868mhz)
- New Device: TYXIA 261/461 X2D micro modules (868mhz) (Receive only, more logs needed)
- New Device: Milight RGB+CCT (a.o. 4-zone FUT092/ 8-zone FUT089)
- New Device: Milight RGB (a.o. FUT098)
- New Device: Bofu motor BF-301, EY1612, EY1624 and others
- New Device: Oregon Scientific SL109
- New Device: AR53002 / AR50055 X2D Thermostats
- New Device: Atlantic MD-210R / Focus MD-210R - 868mhz door contact
- New Device: Legrand CAD Radio
- New Device: Gelia EMW100T switch set
- New Device: ELEC EDB-40 / QH-1085TX V1.1 Quhwa doorbell
- New Device: X10 Sensors
- New Device: Ambient FT004T temperature sensor
- New Device: Ambient FT004B temperature sensor
- New Device: ASA radio technology Go-1
- New Device: Telis 4 Modulis RTS
- New Device: Added support for a new version of the Rubicson WT0122 pool thermometer
- New Device: Renkforce E0190TA and compatible temperature sensors
- New Device: Ematronic AC114-01B shutter/blinds controller
- New Device: Yooda Melody shutter/blinds controller
- New Device: Viking 02813 Temperature sensor
- New Device: Marquant 943134 Temperature sensor
- New Device: Arlec RC10 switch set
- New Device: V2 Phoenix remote signals (Receive only)
- New Device: IDK CAR-200 doorbell (Receive only)
- New Feature: GPIO pin state at boot can be selected with a wire from pin 5 to ground to set the pin default to high
- Added: X2D/X3D protocol support
- Added: Milight RGB and RGB+CCT protocol support
- Added: Direct dimming support for Flamingo and compatible devices
- Added: Additional WH3 detection
- Added: Two Additional Dooya protocol flavors
- Added: Additional Dooya signal recognition
- Added: Additional Blyss remote control recognition
- Added: Additional Brell remote control recognition
- Added: STOP command support to (first) extended RTS protocol version
- Added: Support for second extended RTS protocol version
- Added: Additional Pair option for Bofu motor devices
- Added: upon request added 6 additional GPIO pin's for generic use
The GPIO pins are often used to 'press buttons' on incompatible devices
- Fixed: Added pairing command for Ansluta
- Fixed: Increased transmission duration for Ansluta
- Fixed: corrected barometric pressure value of BTHR918
- Fixed: UPM Esic negative temperatures
- Fixed: Further improved X10 protocol detection
- Fixed: 'newkaku' send command handling improved
- Fixed: 'newkaku' group commands put at a unique switch number
- Fixed: imrpoved newkaku filtering
- Fixed: improved Acurite SL109 negative temperature handling
- Fixed: CM113 ampere precision
- Fixed: Milight: bug in unit selection
- Fixed: bug with the number of RFCustom records
- Fixed: removal of RFCustom records
- Fixed: Improved Xiron sensor detection
- Fixed: Alecto rain meter values
www.rflink.nl
R47: (15/09/2017)
www.rflink.nl
