Hi there,
i have an Remote controllable (433MHz) Sunblind from Obi.
Inside there is an LED-Stripe. Almost everything works like a Charme with RFLink, Motor-Controll is recognized as Brelmotor, Colorchange, Speed of Colorchange, Dim is recognized as EV1527.
Only the button for switching on and off will not be recognized. Its a toggle Button, press once on, press twice off.
Debug is here ( pressed Button 3 times )
20;D5;DEBUG;Pulses=82;Pulses(uSec)=4530,1470,240,690,210,690,570,330,210,690,570,360,210,690,240,690,210,720,240,690,570,330,210,690,210,690,210,690,210,690,570,330,210,720,570,330,570,360,570,330,570,330,210,690,210,690,210,690,570,360,240,690,570,330,210,690,210,690,210,690,210,690,210,690,210,690,240,690,210,690,210,690,210,690,570,330,570,330,570,330,570,6990;
20;DA;DEBUG;Pulses=82;Pulses(uSec)=4530,1470,240,690,210,720,570,330,210,720,570,330,210,690,210,690,210,690,240,690,570,330,240,690,210,690,210,690,210,690,570,330,210,690,600,330,570,330,570,330,570,330,210,690,210,690,210,690,570,330,240,690,570,330,210,690,210,690,210,690,210,690,210,690,210,690,240,690,210,690,210,690,210,690,570,330,570,330,570,330,570,6990;
In RFLink Log:
rflink.0
2017-09-17 20:47:16.454
warn
Wrong serial data: 2842f1400f000000
rflink.0
2017-09-17 20:47:16.155
warn
rflink.0
2017-09-17 20:47:15.745
warn
rflink.0
2017-09-17 20:47:15.295
warn
Thank you.
Matthias
Awning/Sunblind from Obi ( Germany )
