Hmmm, so it saved it and then blew up. Thx! makes it easier to find out what happened.BertB wrote: ↑07 Jan 2018, 14:26The wifi settings are filled in correctly in the config page.LisaM wrote: ↑07 Jan 2018, 13:55In your first run, there was no open wifi network available, so it should have exited with the network not available warning message mentioned in the first post. It didn't so it's probably a bug i need to hunt and fix.BertB wrote: ↑07 Jan 2018, 12:45 this is weird ...
an hour or so later, I restarted the Putty terminal into the ESP32 and tried upyeasy.setwifi again.
it was not found, so I imported it again.
After that I did upyeasy.main() and now it connects to my network.Code: Select all
upyeasy.setwifi('xxxx','yyyyyyy') Traceback (most recent call last): File "<stdin>", line 1, in <module> File "upyeasy/__init__.py", line 29, in setwifi File "upyeasy/utils.py", line 42, in setwifi File "filedb.py", line 70, in update AttributeError: type object 'networkTable' has no attribute '__fields__'
In the second attempt it probably found a open network (or the network wifi command also has a bug and did store it but then exploded). If it's running you'll need to check if the ssid fields are fillend in at the config page. Please let me know if they're filled in or not (so i know what direction to look for when hunting the bug).
In your logfile also the ssid names are visible, i don't know if you care or not but if you do: replace them with xxxxxx (but not the other data).
ESP32 boards
Re: ESP32 boards
Re: ESP32 boards
Hi Lisa,
BME280 is basically working for me, on LOLIN32 LITE board. And it's stable (touch wood!).
Temperature and pressure look fine,
but unfortunately Humidity is stuck on zero all the time, which seems unlikely here in Shropshire UK.
I also noticed a few "cosmetic" points.
1, The Humidity value is displaced to the left compared with the others. 2. if I narrow the window in which uPyEasy is displayed, the page-tab headings go onto the second line (as expected) but the rest of the page does not move down to make extra space, so the second line tabs try to overlap the screen display and are partly hidden. 3. I have the same problem with the Decimals fields as I found with the DS18 (not being saved/re-displayed, and not controlling the values shown.)
Cheers
Andrew
Cheers
Andrew
Re: ESP32 boards
Hi Lisa,
On a more general note, regarding issues or bugs that we testers may find.
Do you prefer to continue to have them through this forum, or to use Github issues now that the repository is set up? Seems to me that Github has possible advantage of keeping all issues together, so maybe easier to track. Possible disadvantage is that not everyone is accustomed to Github. A third way is to mention them on the forum, and then create an issue in Github.
How do you see it?
Andrew
How do you see it?
Andrew
Re: ESP32 boards
I'm slowly but steadily losing track of all reported bugs here, so i'm definitely moving towards Github. I really prefer that bugs are logged in Github now that the repository is up and running. If you don't have a github account then this post is the alternative, but will be secondary to Github (meaning that your bugreport might not be answered, especially if it takes longer to solve the bug).AndrewJ wrote: ↑07 Jan 2018, 21:25 Hi Lisa,
How do you see it?
Andrew
Re: ESP32 boards
Thanks, that's fine, I have an account already so shouldn't be a problem. I'm still fairly new to it but getting there!
I'll put the ones I reported already into Github, and use it for any future issues.
Cheers
Andrew
Cheers
Andrew
Re: ESP32 boards
Do you know for sure you have the BME280 and not the BMP280?AndrewJ wrote: ↑07 Jan 2018, 21:15 Hi Lisa,
Cheers
Andrew
They are almost the same, but the BME version also measures humidity.
And are the 1-wire sensor and the BME/BMP measuring the same? Then the displayed temperature of the Bosch sensor is about 9 degrees off.
Re: ESP32 boards
Hi TD-er,TD-er wrote: ↑09 Jan 2018, 09:24Do you know for sure you have the BME280 and not the BMP280?AndrewJ wrote: ↑07 Jan 2018, 21:15 Hi Lisa,
Cheers
Andrew
I think you may have pointed out the explanation of the zero humidity values. I checked the identification on the module, and it actually says "BME/P 280" So it's possible that in reality is BMP. Chinese clone.
I'll check later, but I may have another module which is definitely a BME and which has given humidity values when connected to a ESP8266 nodemcu. If so, I'll test it with the ESP32 and report back.
Thanks for your input!
Andrew
Re: ESP32 boards
If you test the latest Mega build of ESPeasy (not the one Lisa made, but for the ESP8266), you'll see what version it is. (use the BMx280 plugin)
I've added a detection routine to show immediately what version is detected.
Re: ESP32 boards
Thanks, TD-er, I'll try that. BTW, did you mean test the latest Mega build on ESP32, or ESP8266?
Meantime, I found my other BMx sensor module and checked it on a nodemcu running ESPeasy Mega (but not yet the latest build). It gives non-zero humidity values which look "sensible". (Even though that one is also labelled "BME/P 280"!)
So, I connected it to my ESP32 and it is also working there, including the humidity value. So the uPyeasy BME280 plugin is fine.
Thanks again for your suggestion.
Re: ESP32 boards
Hello @BertB,
Thanks for this suggestion, I tried it and it worked. It now starts automatically without typing these commands each time. (LOLIN32 Lite board).
AndrewJ
Re: ESP32 boards
Hi Lisa,
Just thought I'd post a screen shot of uPyEasy on my Lolin32 Lite board, working with three DS18B20 sensors (it seems these have to be on separate pins) and a BME280 showing all three readings (temperature, humidity, and pressure) and running nice and stable.
It starts automatically, thanks to BertB for his suggestion to add a main.py file.
Still using port 9000.
Thanks for all the hard work you have been putting in. Please continue, within the time you have available, and let me know if I can help at all.
AndrewJ
AndrewJ
Re: ESP32 boards
Cool!!!AndrewJ wrote: ↑09 Jan 2018, 17:25 Hi Lisa,
AndrewJ
The DS's should be able to run on one pin, but maybe the plugin can't handle that yet. I haven't tested that out so far.
I'm busy documenting the architecture and database contents, so that you'll understand how uPyEasy operates.
Re: ESP32 boards
I tried this first time around, with just two DS's, but they interfered with each other and both ended up looking at the same ROM address and reporting the same value as each other. It would be good to do that eventually, to match the ESP8266 version (it would simplify wiring, and use less pins too ) but it is probably best to spend time on developing the rest of uPyEasy, unless someone particularly needs that extra functionality.The DS's should be able to run on one pin, but maybe the plugin can't handle that yet. I haven't tested that out so far.
I'll raise an Issue on Github for this so it doesn't get lost.
That sounds good.I'm busy documenting the architecture and database contents, so that you'll understand how uPyEasy operates.
Re: ESP32 boards
Version v54 has been created op put in the releases dir of the uPyEasy github: https://github.com/letscontrolit/uPyEas ... /tag/ALPHA
The following functionality has been added:
Added Save Settings (saving your config)
Added Files (Files Explorer, see all dirs/files in the ESP32 flash area, where you can edit/delete/add them)
This is the LAST alpha, the coming week(s) i'm busy documenting uPyEasy (including Togaf 9.1 based Architecture Guidelines, since i'm certified and working as a Data Architect) and transferring the source code to the Github repository. The first new version will then be BETA-1.
- Config page
- Tools page
Re: ESP32 boards
This is getting better each time I look.
Re: ESP32 boards
Thanks for all your hard work on this!
Re: ESP32 boards
Hi Lisa,LisaM wrote: ↑13 Jan 2018, 13:20 Version v54 has been created op put in the releases dir of the uPyEasy github: https://github.com/letscontrolit/uPyEas ... /tag/ALPHA
The following functionality has been added:Added admin password (password protected uPyEasy!)
- Config page
Added Load Settings (restoring your config)
- Tools page
Many thanks for that. It's working on my LOLIN32 LITE board with no immediate problems.
(I'm still finding that I need to change to port to 9000 to avoid the 128 error, but I've got it off to a fine art now!)
I'll give it a try on my recently-arrived LOLIN32 Pro soon.
Regarding the DOIT devkit v1 - revision 0 chip, I've more or less given up on it. It just seems very unreliable, I think there may be issues with the power supply end but even attempts to use it with an external supply failed.
Looking forward to the BETA-1 when it's ready!
Andrew
Re: ESP32 boards
Hello, thank you for your development
I try the upyeasy for amusing on my Wemos ESP32 lolin oled and that work
If i use a AP wifi open without key, it's ok, on the other hand if i tried an other AP with WPA_PSK, i lost the connexion and i must reset the esp32, an idea
I ested the command upyeasy.setwifi with more combination, but error
I tested a switch with domoticz, doesn't work, it was fast test.
I you want, i can test a oled plugin
>>> upyeasy.setwifi ('IOT','xxxxxxxxxx','','',80)
File "upyeasy/utils.py", line 46, in setwifi
File "filedb.py", line 73, in update
OSError: [Errno 2] ENOENT
Re: ESP32 boards
when attempting to flash using :
esptool.py --port COM9 write_flash --baud 460800 --compress 0x1000 upyeasy_v54_20180113_test_esp32_2048.bin
i get:
esptool write_flash: error: argument <address> <filename>: Must be pairs of an address and the binary filename to write there
any tips?
scratch that, removed the "baud" statement and it flashed. leaving this here in case it's helpful to someone else
i get:
any tips?
Re: ESP32 boards
I hate it when stuff does not work reliably.
I think I followed all the steps in the books.
I have Python36 and pip and ampy and pyserial.
When I start pyton i get the >>> signs
when I enter import serial, again I get >>>
But when I enter esptool.py --port COM6 erase_flash in the shell, I get
File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module>
import serial
ImportError: No module named serial
What stupid thin am I forgetting?
Oh, by the way, some week ago I got it working.
And I really want to play with upyeasy Beta ....
import serial
Re: ESP32 boards
Espressif instructions: https://github.com/espressif/esptoolBertB wrote: ↑28 Jan 2018, 16:17 I hate it when stuff does not work reliably.
import serial
More help on installation of esptool: https://diyprojects.io/esp-easy-flash-f ... y-esp8266/
Re: ESP32 boards
Thanks, but i did that:
D:\Program Files>cd python\python36
D:\Program Files\Python\Python36>esptool.py --port COM6 erase_flash
import serial
D:\Program Files\Python\Python36>pip install esptool
Requirement already satisfied: esptool in d:\program files\python\python36\lib\site-packages
Requirement already satisfied: ecdsa in d:\program files\python\python36\lib\site-packages (from esptool)
Requirement already satisfied: pyserial>=2.5 in d:\program files\python\python36\lib\site-packages (from esptool)
Requirement already satisfied: pyaes in d:\program files\python\python36\lib\site-packages (from esptool)
D:\Program Files\Python\Python36>esptool.py --port COM6 flash_id
import serial
D:\Program Files\Python\Python36>mode
Status for device COM6:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: OFF
RTS circuit: OFF
Re: ESP32 boards
Path set correctly?:BertB wrote: ↑28 Jan 2018, 16:46 Thanks, but i did that:
D:\Program Files>cd python\python36 D:\Program Files\Python\Python36>esptool.py --port COM6 erase_flash Traceback (most recent call last): File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module> import serial ImportError: No module named serial D:\Program Files\Python\Python36>pip install esptool Requirement already satisfied: esptool in d:\program files\python\python36\lib\site-packages Requirement already satisfied: ecdsa in d:\program files\python\python36\lib\site-packages (from esptool) Requirement already satisfied: pyserial>=2.5 in d:\program files\python\python36\lib\site-packages (from esptool) Requirement already satisfied: pyaes in d:\program files\python\python36\lib\site-packages (from esptool) D:\Program Files\Python\Python36>esptool.py --port COM6 flash_id Traceback (most recent call last): File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module> import serial ImportError: No module named serial D:\Program Files\Python\Python36>mode Status for device COM6: ----------------------- Baud: 115200 Parity: None Data Bits: 8 Stop Bits: 1 Timeout: OFF XON/XOFF: OFF CTS handshaking: OFF DSR handshaking: OFF DSR sensitivity: OFF DTR circuit: OFF RTS circuit: OFF
Python -V
esptool.py -h
pip uninstall esptool
pip install esptool
Re: ESP32 boards
I can start python from everywhere on the pc
after issuing Path, I get a lot of stuff, including:
D:\Program Files\Python\Python36\Scripts;D:\Program Files\Python\Python36
C:\Users\berbe>python -VCode: Select all
Python -V
Python 3.6.2
D:\Tools\uPython>esptool.py -hEsptool version?:Code: Select all
esptool.py -h
import serial
Does not seem to help at all ...Re-installing?:Code: Select all
pip uninstall esptool pip install esptool
But when I first start python and then import serial:
D:\Tools\uPython>python
Python 3.6.2 (v3.6.2:5fd33b5, Jul 8 2017, 04:57:36) [MSC v.1900 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
Re: ESP32 boards
Solved it ... I got one esptool.py to many ...
Re: ESP32 boards
yeah ... growing up hurts ...
But, I had a esptool in the directory of Python36.
And one in Lib/site-packages.
When I run esptool from site-packages, there is no nagging about serial.
So, I removed esptool from the home directory of Python.
Now I have the following:
'esptool.py' is not recognized as an internal or external command,
operable program or batch file.
So, that was the wrong de-fuse wire
In site-packages is also the serial directory.
So, where do I put all this stuff?
Re: ESP32 boards
In powershell:BertB wrote: ↑28 Jan 2018, 18:53 yeah ... growing up hurts ...
esptool.py.exe
ls Env:
Re: ESP32 boards
Hi Lisa,
great work.
I installed the beta yesterday on an ESP-32 Dev board
It works, only the performance of the webinterface is not as good as in your videos.
Many of us would like to participate in the event in a timely manner.
Is it possible to provide Nightly Build?
Can you tell us how to compile the source code from Github?
How do you access the file system of the ESP? For example, to exchange .py files.
Many greetings Peter
great work.
- upEASY.jpg (80.27 KiB) Viewed 85321 times
Re: ESP32 boards
Hi Peter,micropet wrote: ↑31 Jan 2018, 15:32 Hi Lisa,
great work.
I'm busy writing the build doc's but will take one or two weeks to complete. Nightly build is on the todo list also.
Here is a guide how to upload files: https://techtutorialsx.com/2017/06/04/e ... le-system/
Re: ESP32 boards
Thank you Lisa,
I am looking forward to it.
I know Ampy, that's really primitive. I thought you had a more comfortable method.
Something like mounting the file system as a drive.
Greetings Peter
Greetings Peter
Re: ESP32 boards
The ESP32 design doesn't allow it, the STM32's all have an usb driver that mimics the flash drive as an usb drive.
You can use ampy (or rshell/mpfshell) and the file commander in uPyEasy tool menu and that's it.
Anything more would take a lot of my time and i'm waisting it on other more important stuff...
Re: ESP32 boards
ok I understand.
But the STM32 has no WIFI and therefore no mqtt integration.
This probably makes the ESP32 most suitable.
- budman1758
Re: ESP32 boards
Re: ESP32 boards
Thank you - already ordered.
WIFI has the advantage for me that I can just put my sensors where I have a 5V power supply.
- budman1758
Re: ESP32 boards
I use those ethernet boards with a Raspberry PI Zero and POE for my homemade security cameras. I send 12 volts to it and use a DC stepdown at the camera. That way the wireless isn't overloaded. Plus, you need power for it anyway so POE makes sense.
Re: ESP32 boards
And now you know where the fast uPyEasy demo came from... Wifi is always slow, 100MB or 1GB ethernet is preferable always! I have my house wired with 40 ethernet connections, together with a 1GB switch it's faster then any wifi ever will be. My gate is 30M from my house, wifi was always unreliable there. Since i have it connected to ethernet, it never failed again.
Re: ESP32 boards
I have about 50 devices here, all connected via WIFI.
None of it is completely reliable. Some run a few weeks, some a few months. Suddenly a device stops sending because it is no longer on the network.
I will test the solution over LAN.
Is the STM32F405RGT6 and the W5500 ethernet card recommended?
The STM32F405RGT6 has little memory.
Or are there better solutions?
Greetings Peter
Greetings Peter
Re: ESP32 boards
Have these 'stalled' devices been up like 49.7 days?
If so. please test with one of the last builds for ESPeasy.
I've added some patches to prevent such crashes.
Re: ESP32 boards
Yes, they are always on.
It is the latest version from the Git. I always flash about 5 devices with the current version.
They have stayed in the network so far. I would have to watch it longer.
One Device with BME280 VEML6040 MH-Z19 TVoc CSS811 SDS021 loses the CSS811, BME280 and the VEML6040 after a few hours. After a reset, the sensors stay away.
Only switching off and then switching on the supply voltage brings it back to life.
There are 2x 10k terminators on the I2C bus. The device ran before with an ESP-32 always without problems. I have no idea why the I2C bus suddenly stops working.
Re: ESP32 boards
Lisa,
here you can compare the performance of my installation. ESP-210 is the Arduino version, ESP-01 is the Python version. The Python version sometimes hangs for a few seconds.
Greetings Peter
Greetings Peter
- Performance ESPEasy.zip
- (1.59 MiB) Downloaded 708 times
Re: ESP32 boards
Peter,
Am i correct to notice that the uPyEasy performance is good, besides the hardware tab?
Cheers,
Lisa
Re: ESP32 boards
Yes, the orange/raspberry pi which have it all, loads of memory and ethernet and wifi, however they have a tradeoff in terms of latency. Besides that, i haven't found so far an I2C python library for the pi's which can be used with micropython.
Re: ESP32 boards
Yes Lisa, most of the time the performance is good.
But there is also a break in between, then it takes a little longer.
Re: ESP32 boards
But real python is running on the Pi.
Also with I2C.
I had built some devices with sensors and PWM for my LEDs a long time ago.
They also did not run so reliably. Often there were problems with the microSD.
The Card was suddenly unreadable.
With my PI3s I booted over a USB stick, that was little better.
Overall, I was not satisfied.
I think the most important thing in lighting control or in sensor devices is reliability. They should never fail.
Also with I2C.
Re: ESP32 boards
The STM32's are build for industrial purposes, expensive but very reliable. That's why they have a very low latency, a ton of sensor inputs en low memory. They run in factories and buildings for decades without hickup. The ESP's are build for consumers, cheap and a lot of memory.micropet wrote: ↑02 Feb 2018, 13:01 But real python is running on the Pi.
Also with I2C.
Re: ESP32 boards
So STM boards ...
I just got a PYBv1.1 with STM32F405RG and flashed it with normal MicroPython .
My machine immediately detected an additional drive with boot.py and main.py.
Wow, great.
Can I simply copy the .py files from your github to this drive?
Unfortunately, I have no experience with microPython.
Greetings Peter
Wow, great.
Greetings Peter
