ESP Easy Webdumper
budman1758
Re: ESP Easy Webdumper
#11 Post by budman1758 » 09 Jan 2018, 22:21
This one worked just fine!! Got a folder full of screenshots just as promised. :mrgreen: :mrgreen:
Still about the same delay. Not a big deal in my opinion.
grovkillen wrote: 09 Jan 2018, 21:55 BUT it might be a bug as well, I'm no top notch programmer as you can tell ;)
Dude. Don't sweat that. NOBODY falls outta their Moma as a top notch programmer. I've looked into it and I can't even begin to "get it". My hats off to all who can.
That's the main reason I like ESPEasy so much. I can actually do things without programming. Rules strech my programming skills to the limit. :ugeek:
#12 Post by grovkillen » 09 Jan 2018, 22:31
Thanks mate! :)
manjh
#13 Post by manjh » 10 Jan 2018, 13:58
I discovered this new development yesterday, downloaded, and decided to dive in and do some testing.
The idea and concept are brilliant: a one-stop tool to extract all info from a unit.
As I am writing this, the tool is working on the download of one of my units.
A few quick remarks.
1. IP address initially comes up with 192.168.0.123. Would be nice if it would remember the last used IP address.
2. after selecting one or more items ot tales a long time before something happens. Thi shas good reasons (I assume), but the ignorant and impatient user will start pressing buttons. Solution: display a blinking text right of the two "Select" buttons. Something like: "Processing, please wait!"
3. After completion, the output is stored in a file with the IP number and timestamp. Excellent. But it will take some more information about what we can do with these files. Can they be fed into a restore function? Or should they be used for manual input only? Also, formatting of the data is not clear.
4. It might be nice to have a simple "Ping-only" function, to check if the unit is online. Could be placed next to the "RUN" button.
5. make the blue action window a bit bigger
6. clear the blue action window when a new "run" starts, so the old content is not confused with the new actions
Hope this helps.
Please take my remarks as positive feedback, I think this tool is very useful and I would like to help improve!
#14 Post by grovkillen » 10 Jan 2018, 14:53
manjh wrote: 10 Jan 2018, 13:58 I discovered this new development yesterday, downloaded, and decided to dive in and do some testing.
Hope this helps.
GREAT input, will take all these into the next release. :) Thank you very much!
manjh
#15 Post by manjh » 10 Jan 2018, 18:36
Forgot this one:
7. Make it possible to copy the output from the blue action window. Perhaps I did something wrong, but I could not select/copy the text. Printscreen is a bit of overkill.
So make the text selectable, or even make a button to copy the text.
manjh
#16 Post by manjh » 10 Jan 2018, 18:42
On the wishlist:
Accept the IP address as parameter when starting the tool. If the parameter is not given, work as it is now, with a user interface.
If the parameter is provided, run the tool with all options selected for the given IP address, and close the tool after completion.
This would allow the user to build an old-fashioned bat file, calling the tool for each and every ESP unit in the system.
Simply add one line in the bat file for each unit.
This would make a single, full backup very easy!
#17 Post by Shardan » 10 Jan 2018, 20:08
One of these tools that make life much easier. :)
+1
#18 Post by grovkillen » 10 Jan 2018, 20:11
I'm on it! Glad more people find it helpful in life :)
#19 Post by grovkillen » 12 Jan 2018, 15:23
8. Batch mode: Accept the IP address as parameter when starting the tool. If the parameter is not given, work as it is now, with a user interface.
Green above is now implemented.
#20 Post by grovkillen » 15 Jan 2018, 14:19
Batch mode is now implemented. You call it using this switch "/IP_NUMBER=" and then point to the ip number. I have not implemented log output if the ip is not correct but it will not continue if the entered number is not an ip number.
The app will exit once the job is completed. Multiple instances of the app should be possible.
manjh
#21 Post by manjh » 15 Jan 2018, 22:00
I downloaded (it is still marked 4th version!), but can't get it to run on Win10.
At first Windows complains about an unknown maker, and after that Avast starts worrying about the file. After a scan it tells me that the file may contain malware. Even when I tell Avast to trust the file, it refuses to run (looks like I have no access somehow) :o
manjh
#22 Post by manjh » 15 Jan 2018, 22:09
Tried again, sosmehow navigated through the Windows and Avast messages and ran the program. Now get "access denied"...
budman1758
#23 Post by budman1758 » 15 Jan 2018, 22:15
manjh wrote: 15 Jan 2018, 22:09 Tried again, sosmehow navigated through the Windows and Avast messages and ran the program. Now get "access denied"...
Try running as Admin and see what happens.
manjh
#24 Post by manjh » 15 Jan 2018, 22:20
budman1758 wrote: 15 Jan 2018, 22:15
That was the 1st thing I tried...
#25 Post by grovkillen » 15 Jan 2018, 22:49
I'd say avast is the "problem".
manjh
#26 Post by manjh » 15 Jan 2018, 23:19
grovkillen wrote: 15 Jan 2018, 22:49 I'd say avast is the "problem".
Correct. I disabled the shields and now it runs fine.
Other question: I'm not sure I have the latest-and-greatest version. Did you put it on github as new version? Or is the "Forth"(... fourth) version the right one?
Also, I wonder why the ping takes so long. I started the tool and it says it waits for a ping.
Then I started a command window, typed the ping command, and it finished four pings before the tool had one done.... why?
#27 Post by grovkillen » 15 Jan 2018, 23:24
I ping twice using powershell. And to be sure that all units have time to respond I have a delay of about 30 seconds. I might need to add more output...? I understand that it seems slow when you get no feedback.
Be aware that I need to cover many different scenarios and this ping is really important that it responds correctly since it will "wake the unit up" and make it ready to connect to.
Latest is 0.00.007 but I didn't put that one in releases.
manjh
#28 Post by manjh » 15 Jan 2018, 23:24
The version I downloaded does not support the parameter, and the blue command window is the same size as I remember it.
So I think I donot have the latest version...
#29 Post by grovkillen » 15 Jan 2018, 23:26
manjh wrote: 15 Jan 2018, 23:24 The version I downloaded does not support the parameter, and the blue command window is the same size as I remember it.
0.00.007 is not in releases only in the code section.
manjh
#30 Post by manjh » 15 Jan 2018, 23:26
grovkillen wrote: 15 Jan 2018, 23:24 I ping twice using powershell. And to be sure that all units have time to respond I have a delay of about 30 seconds. I might need to add more output...? I understand that it seems slow when you get no feedback.
OK, understand. But I would think that as soon as the unit responds to a ping, the tool can proceed... the 30 second timeout does not come into the play until the unit remains "dark"!
manjh
#31 Post by manjh » 15 Jan 2018, 23:27
grovkillen wrote: 15 Jan 2018, 23:26
Ah, that explains it.
For speed of testing, could you send the exe to me via mail? You have my mail address... ;)
#32 Post by grovkillen » 15 Jan 2018, 23:27
True! Will make a check in the next release. Thanks
#33 Post by grovkillen » 15 Jan 2018, 23:29
manjh wrote: 15 Jan 2018, 23:27
You can download the exe from the code section. The APP_DATA.zip is unchanged so just replace the exe.
manjh
#34 Post by manjh » 15 Jan 2018, 23:35
Never mind, got it.....
manjh
#35 Post by manjh » 15 Jan 2018, 23:47
OK, some quick (unstructured) test results.
1. when I start the tool it comes up with the default IP address. I changed that to one of mine and ran it, then closed the tool and restarted. The IP address is again your default (so my last used address is not remembered).
2. when I start the tool in batch mode with an IP address as parameter, it runs the tool but it fails to select all options. Result: no much is downloaded...
3. unit name and number is not found, I tried on build 147 and also on the Mega release.
4. output files are not clear to me, I tried to look at a few but I will need more time to study the structure. I was expecting simple screenshot files. But this could be my mistake, perhaps I opened the files in the wrong way?
#36 Post by grovkillen » 16 Jan 2018, 05:59
You need to save the settings. Batch mode will use these default settings. ;)
Regarding the output files and unit name. These should be straight on screen shots and the name and number should be found. If not that tells me you didn't have the correct IP number? Can you confirm that the IP is that of a ESP Easy unit?
manjh
#37 Post by manjh » 16 Jan 2018, 14:59
grovkillen wrote: 16 Jan 2018, 05:59 You need to save the settings. Batch mode will use these default settings. ;)
I tried on a few different ESP's. In fact, am running one now: it complains about unit name/number, and then proceeds with the other screens with no problems.
I will compress a few of the outputs and send them to you.
One question stays in the back of my mind. When I browse into the ESP unit, it asks me to log on with userid/password (I configured it like that). How does your Web dumper pull the information out of the ESP's without knowledge of those credentials?
manjh
#38 Post by manjh » 16 Jan 2018, 15:05
Tested and confirmed.... works great!
#39 Post by grovkillen » 16 Jan 2018, 15:35
manjh wrote: 16 Jan 2018, 14:59 One question stays in the back of my mind. When I browse into the ESP unit, it asks me to log on with userid/password (I configured it like that). How does your Web dumper pull the information out of the ESP's without knowledge of those credentials?
Whoooops! That's probably it. I guess some pages are not protected by the password (JSON, SDCARD, CONFIG etc).
Thanks for that input, and we need to go to the bottom on that one since downloading the config will let you clone a unit and get onto the network fairly easy. Lets try all the pages and file the findings to GitHub.
manjh
#40 Post by manjh » 16 Jan 2018, 15:38
grovkillen wrote: 16 Jan 2018, 15:35
I would expect that all pages are protected by the login credentials. If any of them are not, that is a security gap...
For the tool it can be solved by adding two fields (userid/password) and store them in the settings.
#41 Post by grovkillen » 16 Jan 2018, 15:39
Yes I will add that. Thanks for the information.
Would you be able to test all the web pages manually?
manjh
#42 Post by manjh » 16 Jan 2018, 15:41
Not really test findings, but more usability suggestions:
1. change the name of the tool (especially the exe file!) to "ESPDumper". It covers the nature of the tool and is easier.
2. when the tool is called in batch mode (so when the parameter is provided), run in "quiet mode". So donot create the popup window.
Reason for this second suggestion: I am now testing with a bat file, pulling info from five units (to start with). I can run this in backhround and do other things in Windows. But each time a new unit is started, I get that popup window taking over the focus... annoying!
#43 Post by grovkillen » 16 Jan 2018, 15:48
manjh wrote: 16 Jan 2018, 15:41 Not really test findings, but more usability suggestions:
1. I might add the possibility to rename the actual file but the name stands :P
2. I will add a /HEADLESS_MODE=1 switch for the command line. I totally understand you there :)
manjh
#44 Post by manjh » 16 Jan 2018, 16:07
grovkillen wrote: 16 Jan 2018, 15:39 Yes I will add that. Thanks for the information.
I will see what I can do.
It seems you are depending on release level. Perhaps we should consider taking another route?
I can see three ways.
First: simply go along all possible page names and pull the complete page out as screenshot. I suspect you were already following this route.
Second, include a special interface in the next release, where the ESP unit simply spits out each and every data element it contains, identified by a data element key.
I realize this is not simple to do, and it may take a bit of storage that we don't have.
Third, again starting with the next release, have ESPEasy dump the entire content of the storage area that is used to store variables, along with the built number to identify how data is stored. Then in the ESPDump tool implement the intelligence to decypher the data area and create nice and readable output from that. Essentially the same as the second option, except that it will not take as much storage in the ESP unit.
Both second and third way has the downside that it will not work until the next release.
Taking screenshots will always work.
manjh
#45 Post by manjh » 16 Jan 2018, 16:09
grovkillen wrote: 16 Jan 2018, 15:48
Name is only relevant for the exe file.
As for the flag, I would suggest something that reflects the purpose, such as /QUIET_MODE,
But why not take quiet mode as default when running with IP as parameter?
#46 Post by grovkillen » 16 Jan 2018, 17:55
manjh wrote: 16 Jan 2018, 16:09
Good idea. :)
#47 Post by grovkillen » 10 Feb 2018, 00:50
rol-rider
#48 Post by rol-rider » 10 Feb 2018, 15:21
sorry for my limited english (google translate)
thank you for this work.
I wanted to test!
but I can not find the screenshot?
the LOG folder does not contain a screenshot. is this normal?
I wonder if I understood how it works?
I only have 3 files in the LOG folder
I use windows 7 (64bits)
thank you
sorry for my English ! i use google translat.
#49 Post by grovkillen » 10 Feb 2018, 16:15
You need APP_DATA.zip to be in the same folder as the exe file.
I will add this as a warning. Thanks for the feedback :)
#50 Post by grovkillen » 10 Feb 2018, 16:32
I have now updated with a new release.
https://github.com/Grovkillen/ESP_Easy_ ... r/releases
rol-rider
#51 Post by rol-rider » 10 Feb 2018, 17:47
thank you for the answer
however, he is in the same folder
#52 Post by grovkillen » 10 Feb 2018, 18:14
rol-rider wrote: 10 Feb 2018, 17:47 thank you for the answer
Do you mind testing current version 0.00.012 (found here): https://github.com/Grovkillen/ESP_Easy_ ... dumper.exe
rol-rider
#53 Post by rol-rider » 10 Feb 2018, 18:49
Yessssssssss 0.00.012 works
It works. Still thank you.
I'm going to take advantage of the French jeedom
#54 Post by grovkillen » 10 Feb 2018, 19:31
Great news :)
Thanks for the feedback.
rol-rider
#55 Post by rol-rider » 14 Feb 2018, 23:55
would it be possible to decrease the size of the files.
with webdumper .... 2.41M !
with capture tool .... 41K, better for forums.
thank
#56 Post by grovkillen » 15 Feb 2018, 05:58
rol-rider wrote: 14 Feb 2018, 23:55 Hello,
thank
I'm gonna look into it. I make uncompressed pictures, will fix it so they are compressed by default.
Oxyandy
#57 Post by Oxyandy » 31 Mar 2018, 03:30
Hi Grovkillen,
An idea, the total time taken !
This could be used as a measure of web-server performance to measure differences in firmwares
Cheers
#58 Post by grovkillen » 31 Mar 2018, 07:54
Sure, that can be added.
Oxyandy
ESP Easy Webdumper & Performance Tool
#59 Post by Oxyandy » 31 Mar 2018, 11:57
Excellent, I was awake for over 36 hours configuring my 'test environment' - I have an older firmware which has not yet failed,
so I have a base line, a few hours 'power sleep' and I am back.
Only 2 firmware versions higher & I see 'bad behaviour' - very pleased, but so much more to do before I track down the exact cause.
If those performance results could go into a file with the firmware version & time taken, that would save 'manual' effort keeping track.
Time to dump the current failing firmware & OTA update the next.
:twisted:
#60 Post by grovkillen » 25 Jul 2018, 13:42
0.01.002 is now available. Fixed problem with not being able to fetch the unit name an number.
