I have the board installed.
I pulled current whole version from github
- first:
this is not compiling on 2.4.0 only 2.3.0
event stated in code:
#include "core_version.h"
#ifndef ARDUINO_ESP8266_RELEASE_2_3_0
#error ESPEasy v2.0 only support Arduino core 2.3.0. (Use the ESPEasy development branch to fix this)
#endif
- when I did it on 2.3.0
and did a total new portable install.: error show up:
_P016_IR:9: error: 'IRrecv' does not name a type
IRrecv *irReceiver;
_P016_IR:10: error: 'decode_results' does not name a type
decode_results results;
Maybe the question is:
which source to take?
I also tried latest mega 20180112 and 13...but running into errors.
I choose the option: normal build.
which source are you using?
Thanks again for supporting me.
compile ESP ESAY MEGA tcp_impl.h not found
Re: compile ESP ESAY MEGA tcp_impl.h not found
Hint: Just delete all _P***.ino files in the src folder you are NOT using. That helps also sometimes to fix compiling issues and reduces the size of the sketch file.
Users browsing this forum: Bing [Bot] and 32 guests
