%systime% not working in controller & NTP issue
Posted: 12 Jan 2018, 19:45
Hello all!
(I'm using Release v2.0-20180112, same is with Release v2.0-20180111, not tried older versions)
I use a Mini D1 ESP8266 module with two sensors, a BMP280 and a SI7021. The data is collected in a SQLite3 database on a Raspberry Pi3. Therefore i configured a controller with Generic HTTP.
The Controller publish string is "wetterstation/sensorwrite.php?ssn=%sysname%&stn=%tskname%&svn=%valname%&sv=%value%&sntp=%systime%". So far this is working except for the %systime%.
In the SQLite database the values are written correctly, but in my field "sd_ntp_time" there is no time but the string "%systime%". In the main page i can see the current local time, when NTP is enabled.
The NTP-function seems to have another bug. I use my ESPs from external places via a DynDNS service. When NTP is enabled, i can not address my ESP, every time i try this, i get an "IP blocked: ip.ad.dr.ess."
With not NTP enabled, i can login to the ESP from external...
Is there a way to fix this issues?
Greetings,
Andi
Greetings,
Andi
