Olympia sensors 868mhz (door, pir, glass, water)
Posted: 23 Feb 2018, 19:32
by ActionHenk
I have currently a Olympia Protect 9061 system, it uses the 868 mhz band.
I want to integrate the pir sensors and door sensors in domoticz with a rflink 868 mhz, is this possible?
It would be nice since then i don't have to buy and install all new door and pir sensors.
I don't have a rflink yet. But before i buy and build one i want to be shure if my Olympia sensors work with rflink 868mhz on domoticz. If this doesn't work out i see no point to build a 868mhz version. Then it would be better to build a 434mhz rf link and buy all new sensors because i have much more choice.
I have one door sensor open now, but i can't read the discription on the chip, so i don't know what chip it uses.
Please help me, greetings Chris!
Re: Olympia sensors 868mhz (door, pir, glass, water)
Posted: 23 Feb 2018, 20:11
by ActionHenk
I forgot to tell, i have also 2 sirenes for this system that i would like to use with rflink868 on domoticz.
Posted: 23 Feb 2018, 22:22
by ActionHenk
Oke got some more info, all the door contacts and pir sensors have the si4010c2 chip in them.
The si4010c2 chip is actually a all in one: 27-960MHZ rf transmitter with a CIP-51 8051 MCU micro controller in it. The PCB also have 4 headers for programming, rx, tx, gnd and 1 unnamed.
I really hope i can do something with my all my installed sensors and RFLink
http://www.farnell.com/datasheets/18102 ... 1519413195
I wonder what chip the sounders have, because they of course receive a signal, but also send a battery low message to the base unit. Maybe a combi chip, or both.
But i can't get them now to inspect because they are hanging high on my house outside.
Hope you guys can give me some more info, i will continue to search the web for more info about what rflink supported sensors use.
greetings!
Posted: 23 Feb 2018, 23:24
by ActionHenk
Another reply,
after a lot of searching i find it is possible to hook up a RFLink to a raspberry pi and use a signalrecorder/scanner/sniffer to log the transmitting signal.
I could then resend that signal (clone) and do nothing with it, that would work for switches it seems. But i need door and pir sensors and sirenes, not to turn a switch on.
So, i need to record/scan the signal, encode it and then turn it in to a protocol or a inverted protocol. For that i need an raspberry pi and some plugin. To bad i choose to run domoticz on a synology instead of a raspberry pi.
https://github.com/sui77/rc-switch/issues/135
https://github.com/sui77/rc-switch/issues/103
http://www.instructables.com/id/Super-S ... utomation/
https://github.com/sui77/SimpleRcScanner
https://github.com/sui77/rc-switch/issues/112
Can someone help me further? Is it already worth buying and building a RFLink 868 mhz? Or am i better of buying and building a RFLink 434mhz and sell all my sensors and alarm base to get some supported sensors?
Posted: 24 Feb 2018, 00:56
by Stuntteam
I doubt it can be done with any d-i-y solution.
The RF signal itself is probably the easy part. The chip supports FSK and OOK. Finding out what signal it sends a matching receiver or transmitter can be used.
However..... the chip also has AES crypto on board!
It is very likely that communication is encrypted and braking the AES encryption is a whole different ball game.
Posted: 27 Feb 2018, 15:38
by ActionHenk
Oke thank you very much for your answer!
I gived it some time to think what was best for me and since i needed to buy and install all new security sensors anyway and ditch all my excisting sensors i decided to go Z-wave for better protection and feedback on critical stuff that needs it and ordered 8 door sensors, 3 pir sensors and 2 sirenes, all z-wave.
Now i don't need an rflink for now, but in the future i will automate my rolling curtains with tubemotors and i think i will control those with rflink, since i don't see a nice z-wave application for it.
So for the time beeing rflink is on a hold here.
Greetings and thanks again for your help!!
Posted: 27 Feb 2018, 15:56
by Stuntteam
Better make sure that z-wave is what you want for security.. because it has its flaws.
