I am zwehn, a heavy fhem house automation user. After some first experience with arduino esp cases I find esp easy to use it to do water metering via esp easy and direct connection to fhem.
I am using the mega-20180214 build.
Reason for register here is that I experience some problems with the generic pulse counter running into an overflow of the time variable which than seems to set the counter to an irregular high value.
I will post that issue in the sofware topic to hopefully find a solution...
So happy to be here and interested to find additional cases, maybe gas metering next....
Zwehn
Greetings from Munic
mega-20180214 with generic pulse counter, fhem, arduino
Re: Greetings from Munic
Welcome and be aware. This is highly addictive
Don't say nobody warned you!
