Sonoff 4ch Pro, ESPeasy button/rule problem
emosbaek
#1 Post by emosbaek » 14 Mar 2018, 18:04
I hope this is the correctly posted.
I'm trying to create a rule where button press activates one of the four relays in the opposite state. It always works for "on", but never for "off". And when its activated for "on" it takes a few seconds and it returns to "off".
My codes for "Rules"
on System#Boot do
	GPIO,15,0
	GPIO,12,0
	GPIO,5,0
	GPIO,4,0
on Button1#Button do
	if [GPIO12#State] = 1
		GPIO,12,0
		SendToHTTP 192.168.1.119,3480,/data_request?id=action&output_format=json&DeviceNum=16&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1
		GPIO,12,1
		SendToHTTP 192.168.1.119,3480,/data_request?id=action&output_format=json&DeviceNum=16&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0
log
167070 : SW : Switch state 1 Output value 0
167073 : EVENT: Button1#Button=0.00
167088 : ACT : GPIO,12,1
167089 : SW : GPIO 12 Set to 1
167096 : ACT : SendToHTTP 192.168.1.119,3480,/data_request?id=action&output_format=json&DeviceNum=16&serviceId=urn:upnp-org:serviceId:S
168133 : Timeout while reading input data!
168138 : SW : GPIO 12 Set to 0
Buttons settings
ESPeasy Button settings.JPG (75.03 KiB) Viewed 10296 times
Relay settings
ESPeasy Relay settings.JPG (75.49 KiB) Viewed 10296 times
Re: Sonoff 4ch Pro, ESPeasy button/rule problem
#2 Post by grovkillen » 14 Mar 2018, 18:38
[GPIO12#State] = 1 should be [Relay1#Switch] = 1 (please do not use spaces in task names). Calling for gpio state is not yet documented and implemented.
emosbaek
#3 Post by emosbaek » 14 Mar 2018, 19:59
grovkillen wrote: 14 Mar 2018, 18:38 [GPIO12#State] = 1 should be [Relay1#Switch] = 1 (please do not use spaces in task names). Calling for gpio state is not yet documented and implemented.
Thank you very much for your reply.
I totally agree. Spaces in task names in code is not good. But added it because i like spaces in overviews and tables. But it's corrected now.
Changed from "state" to "switch". (also changed button value from "Button" to "press". more code friendly)
The is the new error: (Just to be clear, i only pressed once)
1493556 : SW : Switch state 1 Output value 0
1493559 : EVENT: Button1#Press=0.00
1493571 : ACT : GPIO,12,1
1493572 : SW : GPIO 12 Set to 1
1493656 : SW : Switch state 1 Output value 1
1493658 : EVENT: Relay1#Switch=1.00
1494586 : HTTP : connection failed
1497935 : SW : Switch state 1 Output value 1
1497937 : EVENT: Button1#Press=1.00
1497949 : ACT : GPIO,12,0
1497949 : SW : GPIO 12 Set to 0
1498035 : SW : Switch state 0 Output value 0
1498037 : EVENT: Relay1#Switch=0.00
1498964 : HTTP : connection failed
#4 Post by grovkillen » 14 Mar 2018, 20:26
Since it's a momentary button it will go to 0 once you release it = making the button#press trigger again. Use this instead :
on Button1#Press=1 do
emosbaek
#5 Post by emosbaek » 14 Mar 2018, 21:13
grovkillen wrote: 14 Mar 2018, 20:26 Since it's a momentary button it will go to 0 once you release it = making the button#press trigger again. Use this instead :
Thank you.
I added the "=1", but it still keeps turning off.
After some investigation i noticed under "Devices" that the pressed button keeps its value high/1 forcing the relay to toggle due to the rule. So i added GPIO,0,0 (which is the button) to run after the GPIO output where changed. But nor in the rule or Tool Commands can i set GPIO 0 low :shock:
34679 : SW : Switch state 1 Output value 0
34681 : EVENT: Button1#Press=0.00
34690 : WD : Uptime 1 ConnectFailures 0 FreeMem 19472
35378 : SW : Switch state 1 Output value 1
35378 : EVENT: Button1#Press=1.00
35384 : ACT : GPIO,12,1
35385 : SW : GPIO 12 Set to 1
35386 : ACT : GPIO,0,0
35386 : SW : GPIO 0 Set to 0
35690 : SW : Switch state 1 Output value 1
35691 : EVENT: Relay1#Switch=1.00
36701 : HTTP : connection failed
39755 : SW : Switch state 1 Output value 0
39762 : EVENT: Button1#Press=0.00
61101 : SW : Switch state 1 Output value 1
61102 : EVENT: Button1#Press=1.00
61109 : ACT : GPIO,12,0
61109 : SW : GPIO 12 Set to 0
61110 : ACT : GPIO,0,0
61111 : SW : GPIO 0 Set to 0
61201 : SW : Switch state 0 Output value 0
61203 : EVENT: Relay1#Switch=0.00
#6 Post by grovkillen » 14 Mar 2018, 22:01
What version do you use?
emosbaek
#7 Post by emosbaek » 14 Mar 2018, 22:14
GIT version: v2.0-20180311
#8 Post by grovkillen » 15 Mar 2018, 05:37
Try latest, some fixes to the rule engine has been made since that version.
emosbaek
#9 Post by emosbaek » 15 Mar 2018, 15:15
Loaded the newest firmware (GIT version: mega-20180315), set it up from scratch without uploading the old config, but still the same problem.
GPIO-0 (button1) stays high after its pressed and relay is latched and wont go low without a hard reset (only solution so far) :|
emosbaek
#10 Post by emosbaek » 15 Mar 2018, 15:48
Well this is awkward.. :oops:
I changed all the dip-swtiches on "K5" & "K6" to 'ON'. Now its atleast locking. Next step is to see if i can press the button to release it :)
As far as i can see, this i hardware related and not software.
admin: feel free to move this to correct forum if needed.
#11 Post by grovkillen » 15 Mar 2018, 15:49
Methuselah
#12 Post by Methuselah » 15 Mar 2018, 23:38
I use a Sonoff 4CH Pro to control a remote antenna switch. Either by sending an event to the controller, or via the buttons. When I press a button, my state changes from 0 to 1 or 1 to 0 and stays that way until I change it again (or a reset).
My configuration:
My rules:
on Button1#Press do
   if [GPIO12#State] = 0
      GPIO,12,1
      GPIO,12,0
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape :)
hacimsenigma
#13 Post by hacimsenigma » 22 Apr 2019, 13:52
Old post I know,
Change the Value from "State" to "Switch"
