Framed OLED. Write commands?
- budman1758
Wondering if you can write to specific lines on the Framed OLED plugin like you can with the regular OLED.
And if so what the command is.
Framed OLED documentation is a bit thin.
Re: Framed OLED. Write commands?
Yes, I plan to make two separate plugin pages. Time is the only thing missing
You sure can... This is how I do it. Just dawned on me... are you looking to do this from rules? If so, I do this:
On Switch#SwitchA Do
If [Switch#SwitchA]=1
OLEDFRAMEDCMD,High
Else
OLEDFRAMEDCMD,Low
Endif
I have not tried to write a line from rules. but would expect a similar command with an address and contents.
OLEDFRAMEDCMD,High
Else
OLEDFRAMEDCMD,Low
Endif
- budman1758
So you can turn on or off and change contrast but not write to individual lines from command line or rules?
I have not tried to write this way.
I think you could look at the oledframed.ino file in the source to see the methods. I may be wrong, not a coder but a user.
- budman1758
I'm the same. Looking at code makes my eyes roll back in my head.
I did look through that file and found the on/off commands. Did not see anything about writing to it though. Guess that is not possible......yet.
There is no write text command for the framed plugin... yet.
A number of issues for the plugin have been added last week, so I guess there will be some changes to that plugin.
One of the things mentioned was to get rid of the "page indicator" and start using those pixels.
And add extra information to the top line (customization string)
And adding write-command was also mentioned.
Related ... where does one ask for features to be added?
With the great Wemos D1 Mini OLED shield the need to set the LCD to 64x48 is there but it can;t be done in the framed OLED device like it can in the non-framed OLED device.
We prefer our users to add features on GitHub since there we got a somewhat working process of handling them. In the forum great ideas tend to get lost in the noise.
Ok cool - thanks ... don't know my way around GitHub much but I'll have a look and fathom it out
It's good for the user as well, you'll get emails of we have done something with your request.
