ESPFinder
ESPFinder
ESP Easy Netscan is a very nice and handy application, thanks to grovkillen..
It's too bad, is just for Windows, so i stealed the idea, and made a simpler looking version in Python3 to Linux fans, like me.
ESPFinder first beta: Source code:
https://github.com/enesbcs/espfinder-python
Re: ESPFinder
Happy to have inspired
Re: ESPFinder
Thanks enesbecs and grovkillen,
I'm also a Linux user, I will give it a try!
Thanks for sharing.
Andrew
Thanks for sharing.
Andrew
Re: ESPFinder
I tried installing espfinder, but I'm getting errors when executing "sudo pip3 install multiprocessing ctypes itertools contextlib". The error is:
Command "python setup.py egg_info" failed with error code 1
Do you know what am I missing?
Re: ESPFinder
I am using Ubuntu Linux 16.04 with latest stable Python 3.5.2 from ubuntu repositories with pip 8.1.1.
Maybe you can try to upgrade pip:
sudo python -m pip install --upgrade pip
sudo pip3 install --upgrade setuptools
Re: ESPFinder
Thanks for your reply. I tried what you proposed - I have the latest versions (the message I get is "Requirement already up-to-date"). I have python 3.5.2 and pip 10.0.1.
The installation of "multiprocessing" fails.
There is something in my installation which is outdated or missing.
Re: ESPFinder
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-663zc296/multiprocessing/
Re: ESPFinder
Maybe multiprocessiong is already installed in a non-pip way which can not be overwritten by pip.
Try to reinstall stdlib:
sudo apt-get install --reinstall libpython3.5-stdlib
Re: ESPFinder
I downloaded multiprocessing-2.6.2.1.tar.gz and the INSTALL.txt says: "Python 2.6 and newer versions already come with multiprocessing."
When trying to install it (using sudo pip3 install multiprocessing) the error I get is:
It seems like the error is that print cannot be followed by ' (single quote) in python3. It has to be "
I also checked in /usr/lib/python3.5 and I have: ctypes, multiprocessing. When I try to execute:
sudo pip3 install itertools
I get the message:
Collecting itertools
Could not find a version that satisfies the requirement itertools (from versions: )
No matching distribution found for itertools
I get a similar message with sudo pip3 install contextlib
Can we somehow compare our installations?
File "<string>", line 1, in <module>
File "/tmp/pip-install-vw9qsdn_/multiprocessing/setup.py", line 94
print 'Macros:'
SyntaxError: Missing parentheses in call to 'print'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-vw9qsdn_/multiprocessing/
I get the message:
Re: ESPFinder
Can you try to run espfinder.py? I think all prerequisites already satisfied, and nothing left to install.
Re: ESPFinder
Thanks again for your reply. I'm afraid it doesn't work
The GUI starts but nothing is displayed. And when I click on "Refresh", I get a lot of errors:
Similarly with the console version
Process Process-1:
Process Process-2:
File "/usr/lib/python3.5/multiprocessing/process.py", line 249, in _bootstrap
self.run()
File "/usr/lib/python3.5/multiprocessing/process.py", line 93, in run
self._target(*self._args, **self._kwargs)
File "espfinder.py", line 35, in pinger
hostadrr = self.ownip.split('.')[:-1]
AttributeError: 'bool' object has no attribute 'split'
Process Process-3:
self.run()
Re: ESPFinder
This means, that the python program are unable to determine your machine local address from the "ifconfig" command output. Can you share the output of ifconfig?
I will have to implement some basic error messages...
Re: ESPFinder
yes, here it is:
$ ifconfig
enp11s0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:17
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4544 errors:0 dropped:0 overruns:0 frame:0
TX packets:4544 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:423546 (423.5 KB) TX bytes:423546 (423.5 KB)
virbr0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
wlp2s0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: xxxx::xxxx:xxxx:xxxx:xxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1311175 errors:0 dropped:0 overruns:0 frame:0
TX packets:1506516 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:541416351 (541.4 MB) TX bytes:1555227741 (1.5 GB)
Re: ESPFinder
I think i get it, i expected eth0-9 and wlan0-9. Fixed, and uploaded to github.
Re: ESPFinder
Thanks! It works
Can I ask something:
when I start the gui, it shows nothing. After I click on Refresh, I get the list of devices. Is this normal?
Thanks again for the implementation and your support!
Re: ESPFinder
You are welcome. Yes the need to click on Refresh is by design, but in the future it can be change.. but first i have to implement some sort of progress feedback. Since i using multiprocessing for fast pinging it is hard to sync a global variable in the main app.
Also developed some sort of Windows compatibility, just for fun, but it is slow as hell.
