ALLNET 4duino IoT WLAN ESP8266-UP-Relais - rx and tx to GPIO
trs123
#1 Post by trs123 » 13 May 2018, 11:42
i am new in this forum. I use about 20 sonoff S20 and 3 sonoff basic with espeasy. Now i flashed this device wkth the newest espeasy Mega version:
https://m.future-x.de/item/313635333639 ... 2gQAvD_BwE
It works very well. I switch my outdoor lamps with it. Now i want to use the Rx and Tx pins for GPIO. One for the bell-button, and one for a relais for the bell. But it wont work. No input or output is possible. Serial is switched of under advanced configuration. Is it possible, to adjust espeay, to work with the device?
In the atachment everything i get from the distributor.
ALL_Relais.zip
(2.98 MiB) Downloaded 37 times
allnet.zip
(92.59 KiB) Downloaded 32 times
trs123
Re: ALLNET 4duino IoT WLAN ESP8266-UP-Relais - rx and tx to GPIO
#2 Post by trs123 » 18 May 2018, 12:30
no chance, to get it work?
This docu i have also:
148814.zip
(425.02 KiB) Downloaded 27 times
#3 Post by grovkillen » 18 May 2018, 12:41
How do you connect the switch? Do you short it by putting GND to the pin?
trs123
#4 Post by trs123 » 18 May 2018, 16:40
I use GPIO 5 (SCL) for lightswitch. GPIO4 (SDA) for a led. Now i want to use GPIO 1 (Tx) for Bell-Button, and GPIO2 (Rx) for a relais for the bell.
trs123
#5 Post by trs123 » 18 May 2018, 16:55
Some pictures of my settings
trs123
#6 Post by trs123 » 18 May 2018, 16:58
Once more
#7 Post by grovkillen » 18 May 2018, 17:22
So you have the gnd connected to the switch/button?
trs123
#8 Post by trs123 » 19 May 2018, 11:29
I tested it on GND (settings: normal switch) . The relais once on GND (settings: push botton active high) and on 3,3V (settings: push button active low). Nothing work.
#9 Post by grovkillen » 19 May 2018, 14:21
Please take good pictures so I can see what you have done. If possible, use colors for the wires (black for GND etc) so I understand more. :)
trs123
#10 Post by trs123 » 19 May 2018, 17:22
It works :x
Relais i used was bad. To much power consumention. Switch works, too. Need to use "internal pullup"
#11 Post by grovkillen » 19 May 2018, 19:07
Yes I'd recommend it to be sure to have the value high when the switch is NO.
