Status of GPIO pin always 0
caco3
#1 Post by caco3 » 14 Jul 2018, 00:20
I have set GPIO13 as an input.
The devices page shows the value correctly as 1 or 0.
Also when I read http://<IP>/json, I can see the correct state:
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"Switch",
"NrDecimals":0,
"Value":1
How ever when I try to read the status using
http://<IP>/control?cmd=status,GPIO,13
the state is always 0:
{ "log": "", "plugin": 1, "pin": 13, "mode": "input", "state": 0 }
What am I missing?
Re: Status of GPIO pin always 0
#2 Post by grovkillen » 14 Jul 2018, 08:23
Have you previously used PWM on that pin? Do a PWM zero command and see if the same is happening? But it sounds like it's the same thing as reported here: https://github.com/letscontrolit/ESPEasy/issues/1551
caco3
#3 Post by caco3 » 14 Jul 2018, 22:54
Thanks for the reply!
I haven't used any PWM functionality, in fact its the first time I configure this device.
In fact it has exactly the same symptoms as in the mentioned bug report. I will further trace it down there.
As a workaround I did the following:
1. Configure a 2nd device, eg on GPIO2.
2. Add the following rule:
on Switch#Switch do
    if [Switch#Switch]=0
        gpio,2,1
        gpio,2,0
Whenever GPIO13 changes, the rule gets executed which sets GPIO2.
GPIO2 now shows the correct state when it gets polled.
