Hi All,
Is currently the MQTT for Domoticz within ESP Easy still 1 way traffic?
I know its written in the Wiki it can only send MQTT to Domoticz and not receive from Domoticz but maybe something has changed and Wiki not updated???
Thanks,
Jerome
MQTT <> Domoticz
Re: MQTT <> Domoticz
You can use a device 'Domoticz MQTT Helper' to set switches or dimmers through MQTT.
Damn that's a workaround ......
Means if i want a switch to be updated from domoticz (via MQTT) i must create a Helper switch together with a rule to get the switch or status back to its original.
Why is the Domoticz/in not implemented would be way more easier i believe.
Really considering right now to use for my Switches Tasmota as then i would have the status and function from MQTT after a reboot of the ESP (MQTT Remain)
Yes, it is a workaround.
But maybe you can implement a better solution and enhance EspEasy...
