Relay status state?
Relay status state?
I am using a Sonoff Switch and i wanted to know if there was a way i could setup if the power is on or off on my gpio pin. i needed to setup something to tell on my website if the light is on or off. not sure on what to research as far as the method to do so
Re: Relay status state?
Easiest way of doing this is to create a switch input of that GPIO. It will then monitor that GPIO as if it was a simple latching button.
Do you have an example of this being done with anything? I can do it myself just need a sample of it being done with anything.grovkillen wrote: ↑14 Aug 2018, 09:18 Easiest way of doing this is to create a switch input of that GPIO. It will then monitor that GPIO as if it was a simple latching button.
If you read on the wiki regarding that plugin (Switch input) you'll see how it's done.
Awesome i figured it out thanks a tongrovkillen wrote: ↑14 Aug 2018, 19:50 If you read on the wiki regarding that plugin (Switch input) you'll see how it's done.
