reading multiple analog sensors
czahn
#1 Post by czahn » 25 Aug 2018, 11:07
Hi !
i have two sensors. A moisture and a photoresistor. I'd like to use both together with a wemos d1 mini, which only has one analog input.
I already wired the vcc to several gpio's and defined a switch to power on/off the sensors. Both Analog output goes to A0 on the wemos.
Now i can switch between the senors, so that only one sensor has power.
Unfortunately the measurements for both senors are not correct. When i connect only one sensor to A0, everything works fine and the measurements are correct.
What do i wrong! Is there any trick?
Thanks a lot!
Regards.
C
Re: reading multiple analog sensors
#2 Post by Shardan » 25 Aug 2018, 11:54
as both sensors are permanently connected to the analog input they influence each other. Sorry, that won't work.
There are several ways out.
First you could replace the photo resistor with a luminosity sensor like TSL2561 or BH1750.
Second you could use a relay to switch the analog input itself instead of powering the sensors via GPIO.
Third you may use an external analog-to-digital converter (ADC) like the ADS1115.
papperone
#3 Post by papperone » 25 Aug 2018, 12:36
3rd solution is the easiest and safer IMHO!
