Thanks for your reply.
I've used your tool (looks nice btw, except for the font but that's due to W10 I see), like the option of setting the wifi details in there.
Everything seems to go okay, but it won't connect. 100% positive my wifi details are correct.
Any ideas?
Here's the log:
######2018-09-28######
#######0.01.001#######
######FLASH INFO######
BIN file: ESP_Easy_mega-20180927_normal_ESP8266_1024.bin
COM port: (COM5) USB-SERIAL CH340
Baud rate: 115200
######POST FLASH######
Unit name: Sonoff2
Unit number: 2
Admin password:
WiFi SSID 1: Donno
WiFi password 1: Password
WiFi SSID 2:
WiFi password 2:
IP: <DHCP>
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM5 -ca 0x00000 -cf "C:\esp\BIN\ESP_Easy_mega-20180927_normal_ESP8266_1024.bin"]
[28-9-2018 15:27:55] esptool v0.4.12 - (c) 2014 Ch. Klippel <
ck@atelier-klippel.de>
[28-9-2018 15:27:55] setting board to nodemcu
[28-9-2018 15:27:55] setting baudrate from 115200 to 115200
[28-9-2018 15:27:55] setting port from to COM5
[28-9-2018 15:27:55] setting address from 0x00000000 to 0x00000000
[28-9-2018 15:27:55] espcomm_upload_file
[28-9-2018 15:27:55] espcomm_upload_mem
[28-9-2018 15:27:55] setting serial port timeouts to 1000 ms
[28-9-2018 15:27:55] opening bootloader
[28-9-2018 15:27:55] resetting board
[28-9-2018 15:27:55] trying to connect
[28-9-2018 15:27:55] flush start
[28-9-2018 15:27:55] setting serial port timeouts to 1 ms
[28-9-2018 15:27:55] flush complete
[28-9-2018 15:27:55] espcomm_send_command: sending command header
[28-9-2018 15:27:55] espcomm_send_command: sending command payload
[28-9-2018 15:27:55] read 0, requested 1
[28-9-2018 15:27:55] espcomm_send_command: receiving 2 bytes of data
[28-9-2018 15:27:55] Uploading 749552 bytes from C:\esp\BIN\ESP_Easy_mega-20180927_normal_ESP8266_1024.bin to flash at 0x00000000
[28-9-2018 15:27:55] erasing flash
[28-9-2018 15:27:55] size: 0b6ff0 address: 000000
[28-9-2018 15:27:55] first_sector_index: 0
[28-9-2018 15:27:55] total_sector_count: 183
[28-9-2018 15:27:55] head_sector_count: 16
[28-9-2018 15:27:55] adjusted_sector_count: 167
[28-9-2018 15:27:55] erase_size: 0a7000
[28-9-2018 15:27:55] setting serial port timeouts to 15000 ms
[28-9-2018 15:27:55] writing flash
[28-9-2018 15:28:07] ................................................................................ [ 10% ]
[28-9-2018 15:28:18] ................................................................................ [ 21% ]
[28-9-2018 15:28:30] ................................................................................ [ 32% ]
[28-9-2018 15:28:41] ................................................................................ [ 43% ]
[28-9-2018 15:28:53] ................................................................................ [ 54% ]
[28-9-2018 15:29:04] ................................................................................ [ 65% ]
[28-9-2018 15:29:16] ................................................................................ [ 76% ]
[28-9-2018 15:29:27] ................................................................................ [ 87% ]
[28-9-2018 15:29:39] ................................................................................ [ 98% ]
[28-9-2018 15:29:40] ............ [ 100% ]
[28-9-2018 15:29:40] starting app without reboot
[28-9-2018 15:29:40] espcomm_send_command: sending command header
[28-9-2018 15:29:40] espcomm_send_command: sending command payload
[28-9-2018 15:29:40] espcomm_send_command: receiving 2 bytes of data
[28-9-2018 15:29:40] closing bootloader
[28-9-2018 15:29:40] flush start
[28-9-2018 15:29:40] setting serial port timeouts to 1 ms
[28-9-2018 15:29:40] setting serial port timeouts to 1000 ms
[28-9-2018 15:29:40] flush complete
[2018-09-28 15:29:40] DONE!
[2018-09-28 15:29:40] Waiting for user input (reset the unit).
[2018-09-28 15:29:58] Proceeding...
[2018-09-28 15:29:59] Sending SERIAL: "..."
[2018-09-28 15:30:02] Sending SERIAL: " Name Sonoff2 "
[2018-09-28 15:30:04] Sending SERIAL: " Unit 2 "
[2018-09-28 15:30:06] Sending SERIAL: " WifiSSID Donno "
[2018-09-28 15:30:09] Sending SERIAL: " WifiKey Password "
[2018-09-28 15:30:12] Sending SERIAL: "Save"
[2018-09-28 15:30:14] Sending SERIAL: "WifiConnect"
[2018-09-28 15:30:14] Serial programming done.
[2018-09-28 15:30:28] ERROR: Unit do not have an IP address.
[2018-09-28 15:30:28] JOB COMPLETED, over and out!
