DHT22 no reading
Posted: 29 Sep 2018, 13:48
I have just received a bunch of DHT22, which I use to get temperature and humidity from various rooms in the house. I have used GPIO 2 to read from the DHT22, but occationally the reading fails, and I get "no reading" if I check using a serian connection and a terminal emulator. If I connect another DHT22, most of the time this will work, and if I then plug back the one that failed, it will now work as expected.
I am using ESP_Easy_mega-20180924_normal_ESP8266_4096.bin as the boot image, and the hardware is Wemos ESP-12F.
Any clues about what might be wrong?
All the best from
Ulf
All the best from
Ulf
