First LED of Neopixel ring always ON [SOLVED]
Posted: 11 Oct 2018, 21:35
by pppp33
Hi there, me too with NeoPixel !
I didn't resist and bout the entire 241-led disk (see photo)
The attachment photo1.jpg is no longer available
I connected them in the correct order and got basic Neopixel work.
Now, the strange thing.
After i send the "on" command to first LED with (as an example):
http://192.168.1.163/control?cmd=neopixel,1,0,0,100
I can't switch it off anymore it, whatever command I send.
It looks like the green led is always ON.
Has somebody got same problem ?
I already tried to change the ring, and got same behaviour.
Thx for help.....
Paolo
Re: First LED of Neopixel ring always ON
Posted: 12 Oct 2018, 01:39
Have you set the correct Strip Type? (RGB / RGBW)
And can you set a 5th parameter to 0 in the command?
// (1) NeoPixel,<led nr>,<red 0-255>,<green 0-255>,<blue 0-255>
Plugin_038_pixels->setPixelColor(event->Par1 - 1, Plugin_038_pixels->Color(event->Par2, event->Par3, event->Par4, event->Par5));
As you can see, there is a 5th parameter used to set the color and maybe that one slips through to the next LED.
Posted: 12 Oct 2018, 14:40
by pppp33
Hello TDer,
I did some more testing, and:
- no visible difference between RGB and RGBW
- led 1 is locked to 100% green
- if I power off the disc, led 1 stays off until first command
- If I issue something like:
http://192.168.1.163/control?cmd=neopixel,1,0,0,0,0,0,0
with some more zeroes,
I get no error, but can't switch off led 1
Thanx in advance for yr help.....
Paolo
Posted: 12 Oct 2018, 21:39
by pppp33
Solved !
I used the same pin for wifi status led and Neopixel output !
Thanx TDer for support !
Regards....
Paolo
p.s. I'm also checking neopixel clock (plugin070) and it's running fine for now....
Re: First LED of Neopixel ring always ON [SOLVED]
Posted: 13 Oct 2018, 15:46
Great to see it now works.
And just out of curiosity, do you have a link (or links) to these rings?
Is it one set or did you just combine all available ring radius boards?
Posted: 13 Oct 2018, 17:51
by jjansen
Posted: 13 Oct 2018, 21:51
Posted: 14 Oct 2018, 10:33
by pppp33
Yes, that's it ! I chose black background.
Just an addition:
i combined BASIC Neopixel AND Neopixel CLOCK plugins, so I can lit up a static pattern (starting at led 61, for example the center LED) AND HMS leds on the outer ring.....
Next step could be fun to have faces/emoji on the disk....
But we need an emoji "painter" and a "block transfer" plugin....
Paolo
Posted: 14 Oct 2018, 11:22
by grovkillen
pppp33 wrote: ↑14 Oct 2018, 10:33
Just an addition:
Paolo
Pictures or it's just talk
Sounds really interesting!
Posted: 14 Oct 2018, 12:18
by pppp33
This is a (ugly) picture of the idea: happy, sad, etc.....
I made it with a (long) sequence of commands like this:
curl
http://192.168.1.163/control?cmd=neopixel,124,100,100,0
but we need something more "human"
regards
Paolo
Posted: 14 Oct 2018, 13:36
by grovkillen
Hehe, looks good
Posted: 14 Oct 2018, 16:35
by pppp33
....and this is the "sad" one....
Posted: 29 Aug 2021, 05:47
by cuacco
pppp33 wrote: ↑12 Oct 2018, 21:39
Solved !
Regards....
Paolo
Hi ... could you show me your code where you set same pin for Wifi Status Led and neopixel, I facing same issue when internet is enable, if I disable internet the issue with first led disappears
Posted: 30 Aug 2021, 22:00
by pppp33
Hi, it's not code, but the configuration of LEDs in Espeasy LED page configurations.
You have to deactivate LEDs status on the pin used for neopixel.
Paolo
